Thread: Broken sway bar
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21 Re: Broken sway bar
    THis ^^^
  2. #22 Re: Broken sway bar
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
  3. #23 Re: Broken sway bar
    Quote Originally Posted by Swiggles View Post
    Moogs are easy to get but I'm telling you they are a waste of money. The links and bushings that come with the bar last longer, my lasted a few months. You can get the energy ones from summitracing.com and you'll have them within a few days.
    Are you talking about blue poly moog or black rubber ones?
  4. #24 Re: Broken sway bar
    Tire choice has more affect on unsprung weight than sway bar selection does.
  5. #25 Re: Broken sway bar
    Quincy, Mass
    Yes the blue moogs
    No more GP 04 Impala SS Indy:
  6. #26 Re: Broken sway bar
    Yes the blue moogs
    I can't argue much, as I might have put 12 months and 6000 miles on them at most.
  7. #27 Re: Broken sway bar
    Feb 2010
    Cleveland
    So? more useless weight is more useless weight.
  8. #28 Re: Broken sway bar
    Quote Originally Posted by addzradd View Post
    I agree, however if you want to argue that it's worth more money over? It's not. The value isn't there.
    But luckily they still make the GMPP bars.
  9. #29 Re: Broken sway bar
    Feb 2010
    Cleveland
    I'll keep my GMPP bar for $80 that's only 10.5 lbs
  10. #30 Re: Broken sway bar
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Why is a solid bar dumb? Don't you want it to be stiff to improve the handling?
    Highest stress during bending and torsion occurs at the periphery of the bar. No need for material in the middle as it basically just adds mass. Diameter is what matters more.
  11. #31 Re: Broken sway bar
    GTP Level Member apierce1289's Avatar
    United States
    When I went looking for my leaky brake line I found that my sway bar had broken too -_- got it for $90 at Advance Auto Parts cause I had a $20 off coupon all I had to buy was a flashlight and some PB Blaster to use the coupon ($20 off any purchase over $100) that coupon couldn't have came in more handy :-) and if anybody's curious it helps to soak the sway bar bolts in PB Blaster a few times and overnight before you try to take it off. My sway bar end links didn't want to come apart easy so I had to use a sawzall to cut the bolts.
    Sent from my DROID RAZR using Xparent Red Tapatalk 2
    Gremlins always seem to show up in pairs, or groups of three with our cars...
  1. How to: Replace your broken ol' sway bar or just upgrade it (97-03)
    By Jakescoots in forum How To Write-Ups/Tech Tips
    Last Post: 11-05-2012, 08:35 PM
  2. Old Thread
    By SpeedGrid in forum General Tech Discussion
    Last Post: 09-03-2012, 09:23 PM
  3. ABS problem and a broken sway bar... Oh what a fun day
    By ronmexico in forum General Tech Discussion
    Last Post: 04-15-2012, 11:25 PM
  4. Sway bar broken
    By skibender in forum General Tech Discussion
    Last Post: 01-20-2011, 07:23 PM
  5. How safe is it to drive with broken sway bar
    By blitz217 in forum Brakes/Suspension/Chassis
    Last Post: 12-09-2008, 01:28 PM
