Thread: Wheel Bearing Bolts - Replace?
Results 1 to 10 of 10
  1. #1 Wheel Bearing Bolts - Replace?
    SE Level Member BlackGS's Avatar
    Central Jersey
    Time to do the front driver wheel bearing - again. Last time I reused the three bolts holding the bearing from the back, but I noticed the service manual is pretty clear about using new bolts. Should I get replacements? If so, where can I find them? New bearing didn't come with them.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  2. #2 Re: Wheel Bearing Bolts - Replace?
  3. #3 Re: Wheel Bearing Bolts - Replace?
    black on black. (dont see that to often) my twin car is here lol
    i reused the bolts too. also doing the d/s front today or tomorrow, its raining today.
  4. #4 Re: Wheel Bearing Bolts - Replace?
    I live here. DirtDog's Avatar
    Jun 2012
    I've never replaced them...I for always stick a drop of lock tight on them ever since my freak accident where a caliper bracket bolt vibrated loose.
  5. #5 Re: Wheel Bearing Bolts - Replace?
    May 2013
    S.E. Michigan
    I'm GUESSING that they are torque-to-yield bolts (like on a lot of cylinder heads) so when you torque them the first time (when they're new) you literally are deforming them a little (it's designed this way) and as a result, it's impossible to reuse them and get the same clamping force as the first time.
  6. #6 Re: Wheel Bearing Bolts - Replace?
    i watched the dealership reuse the hub bolts on my 03 GMC truck. 3 times on each side. then i tore the front wheel off 2 times same side both times. so add 2 more hubs to the list. bolts to the hub were re used every time.
    if they really wanted you to change the bolts the hub would come with new bolts. dab of loc tight and make em good and tight works just fine.
  7. #7 Re: Wheel Bearing Bolts - Replace?
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    I replace them when I do wheel bearings, if they come loose at all it's not something I want to have happen. Besides if your already spending $200 or so on a new set of bearings might as well drop the $5 for new bolts, espcially when it says in bold font to replace them.
  8. #8 Re: Wheel Bearing Bolts - Replace?
    May 2013
    S.E. Michigan
    Talked to a coworker who has done many of these hub bearings on his and his daughter's car: he says they're not torque to yield bolts to his knowledge (contrary to my first post) but that it's such a nasty environment down there that those bolt heads could deteriorate and get difficult to remove and replace (repeat repeat) them without risking stripping the heads.. and that's why they encourage you to replace them.. just his thoughts I don't know if it's true.
    So I guess I don't know what to believe for sure but I like addzradd's answer of if you're spending $200 and the shop manual says get new bolts it's cheap insurance.
  9. #9 Re: Wheel Bearing Bolts - Replace?
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    Quote Originally Posted by miken123 View Post
    I could buy this explanation. I've replaced the rear bearings and getting ready to do it again. Those puppies get seized up in the knuckle and are a PITA to remove. (Hint: Heat up the knuckle with a torch). So, replacing them because of the possibility of them seizing is quite plausible.
  10. #10 Re: Wheel Bearing Bolts - Replace?
    May 2013
    S.E. Michigan
    Quote Originally Posted by tdm571 View Post
    Yup the same coworker highly recommended using a torch to warm up the bolts saying that'd loosen any lock tite on them. Good ideas everyone.
  1. Red or Blue Threadlocker for Axle Hub Bearing Mounting Bolts?
    By GT997 in forum Brakes/Suspension/Chassis
    Last Post: 01-23-2012, 06:40 PM
  2. ABS wheel bearing/hub on non ABS car?
    By Captain Bravo in forum Brakes/Suspension/Chassis
    Last Post: 01-01-2011, 03:15 PM
  3. How easy is it to replace a bad wheel bearing?
    By Bjm5295 in forum Tires & Wheels
    Last Post: 05-28-2010, 01:02 PM
  4. Replace cam bearing with engine still in?
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2008, 09:05 PM
