I've seen it wear the pads are the problem, like the metal piece that slides into the slides is not the right size so when the brake is pressed, the pad moves forward and you hear the sound.
That was the case with the Callahan pads i first installed, the O'really Brake best select ceramic is what i had to replace with. They fit snug enough to not move around but still slide through.
