Thread: GP 2008 shaking steering wheel above certain Speed
Results 1 to 17 of 17
  1. #1 GP 2008 shaking steering wheel above certain Speed
    Mar 2013
    Canada
    I think this is a weird one, my steering wheel shakes only sometimes between the speeds 90-95Km but only sometimes and not all the time. I had my tires balance, Alignment done, Outer rods replaced as they were bad and everything else shocks etc.. looks good. Just last week I put on new rotors and pads in the front as I needed to replaced them and also hoping to resolve the shaking issue but its still there. The weird thing is that it only happens sometimes when I let go of the gas going between 90-95KM it shakes, anything under that or above that no shaking at all. The shaking is not that crazy or anything but I do notice it when it does happen. I remembered before I put on my winter tires I was still getting it so I know its not the tires, anybody think of something else that can may cause the shaking issue. Thanks
  2. #2 Re: GP 2008 shaking steering wheel above certain Speed
    I live here. DirtDog's Avatar
    Jun 2012
    Sounds like maybe a bad CV half shaft. Im having a similar problem now and I know that's what mine is. Check to see if the boots on the CV shaft are leaking grease
  3. #3 Re: GP 2008 shaking steering wheel above certain Speed
    Because Firebird Govna47's Avatar
    May 2011
    Oak Ridge
    had same problem with firebird. shop fixed it 1-2-3
    2001 Pontiac Firebird 3.8L V6 - now accepting donations for new rear end - woot
    Why There's a Firebird Invading your Zone
    2001 Ferd Exploder Sport 4.0
  4. #4 Re: GP 2008 shaking steering wheel above certain Speed
    Jun 2012
    Quote Originally Posted by Govna47 View Post
    Shops charge to much...diy it ain't hard
  5. #5 Re: GP 2008 shaking steering wheel above certain Speed
    May 2011
    Oak Ridge
    car was in anyway because dad crashed her
  6. #6 Re: GP 2008 shaking steering wheel above certain Speed
    Mar 2013
    Canada
    Govna47 what is 1-2-3 mean? The shop checked the CV shaft boot but nothing no leaking grease. Can it be from the right side? Or can it be leaking from the inner boot?
  7. #7 Re: GP 2008 shaking steering wheel above certain Speed
    Mar 2013
    Canada
    So I am bringing this post back to life. As I remembered the shaking at high speeds been there for two years, I have already gotten new tires, happens with my winter tires also. The work I have done so far on the car is replaced both front outer tie rods, replaced front and rear struts and mounts. Replaced rear stabilizer bar, replaced steering wheel shaft and also new pads and rotors on the front. I still have the shaking vibration when going 90-100km and I can see and feel the steering wheel shaking. I think it's been awhile and need to get this fix as it's annoying me now. Thanks
    Sent from my iPad using Tapatalk
  8. #8 Re: GP 2008 shaking steering wheel above certain Speed
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Check your LCA bushings and ball joints, inner tie rods, wheel bearings, axle shaft also are a possibility. Double check rims arnt bent, wheels are balanced good with no broken belts or deformations and all bolts are tight. I'm having the same problem, putting money on axles because mine have slung most of the grease out of them.
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  9. #9 Re: GP 2008 shaking steering wheel above certain Speed
    Mar 2013
    Canada
    Well I know it's not my tires or rims as it happens with my winter tires and with winter rims. Will ask my mechanic what he thinks the issue may be.
    Sent from my SGH-I337M using Tapatalk
  10. #10 Re: GP 2008 shaking steering wheel above certain Speed
    Apr 2012
    Dayton, OH
    If you jack front of the car up one wheel at a time and push n pull it at the 9 and 3 and 12 and 6 positions see if has any play.
    2012 F150 STX
  11. #11 Re: GP 2008 shaking steering wheel above certain Speed
    Apr 2013
    White Lake
    I think I might be having the same problem as well... I work off a dirt road that most of the time is like driving on the moon with gravity of course! I noticed when going between 45-70 I can feel the steering wheel shake a little and I also can feel it when i'm going around turns.
  12. #12 Re: GP 2008 shaking steering wheel above certain Speed
    Mar 2013
    Canada
    It might be my inner tie rods, getting new tires in a few days so will try and see if the vibration is gone
  13. #13 Re: GP 2008 shaking steering wheel above certain Speed
    Apr 2012
    Dayton, OH
    If it is, the guy putting your tires on should notice it if he is worth anything. To make sure ask them to see if there any wiggle in the front tires.
    2012 F150 STX
  14. #14 Re: GP 2008 shaking steering wheel above certain Speed
    Mar 2013
    Canada
    Perfect will do
  15. #15 Re: GP 2008 shaking steering wheel above certain Speed
    Nov 2011
    NY
    If you've gone through all your suspension components and they are good, and still have the issue, it could be your engine or tranny mounts being shot and throwing off the geometry of the suspension causing vibration as you mention. Just an FYI.
  16. #16 Re: GP 2008 shaking steering wheel above certain Speed
    Mar 2013
    Canada
    I put on my summers tires yesterday and the vibration has decreased alot but will confirm it in few days when I do more driving on them. I have not yet installed the new tires as I am still waiting for them to come in however what do you guys think about goodyear brand tires? I bought the eagle sport tires by goodyear and there are mix reviews.
  17. #17 Re: GP 2008 shaking steering wheel above certain Speed
    Mar 2013
    Canada
    Installed new tires and no more shaking thanks again guys for your help
  1. Wheel speed sensor
    By GXPrunner06 in forum General Tech Discussion
    Last Post: 03-22-2013, 10:30 AM
  2. 2008 Grand Prix GXP wheel speed harness install
    By dgrinnell in forum Brakes/Suspension/Chassis
    Last Post: 05-20-2012, 09:13 AM
  3. No power steering at any speed!
    By Matt in forum Brakes/Suspension/Chassis
    Last Post: 01-19-2012, 10:59 AM
  4. Steering wheel shaking a little after tire rotation
    By Haulero in forum General Tech Discussion
    Last Post: 12-08-2009, 09:56 PM
  5. Shaking at highway speed
    By 07gpgt in forum 04+ Specifics
    Last Post: 10-07-2009, 06:43 PM
