Thread: Tie Rod Nut Stuck.. any suggestons?
Results 1 to 8 of 8
  1. #1 Tie Rod Nut Stuck.. any suggestons?
    Jul 2010
    Chicago
    Changing my tie rods on a 99 gtp, can't find any pair of vise grips or anything to get the damn lock not off at the end of the outer tie rod on either side. The actual tie rod end comes off with no effort though. Tried map tourch, 3 pairs of vise grips holding the rod, pipe wrenches, and yes i tried the half inch wrench to hold the rod but that stripped right away. I'm taking it to get an alignment tomorrow maybe just let them worry about it?? Pissing me off anyone have suggestions??
  2. #2 Re: Tie Rod Nut Stuck.. any suggestons?
    Banned
    Sioux Falls, SD
    Let them deal with it if they have to align it they will get it loose. When i've done alignments we have had to heat the hell out of them sometimes
  3. #3 Re: Tie Rod Nut Stuck.. any suggestons?
    Jul 2010
    Chicago
    Thats what I thought, I'm done messing with it. Thanks for the fast reply.
  4. #4 Re: Tie Rod Nut Stuck.. any suggestons?
    I always leave the outer tierod in the knuckle and use a big adjustable wrench and they always break free.
  5. #5 Re: Tie Rod Nut Stuck.. any suggestons?
    Jul 2010
    Chicago
    When I did that the whole rod with the nut stuck to it just spins as the tierod end with the knuckle loosens off. I can't find anything that can hold the rod in place so I can break the nut free. I've heard heat is best but I couldnt get it with my map tourch.
  6. #6 Re: Tie Rod Nut Stuck.. any suggestons?
    I do what Dan said.. yet to have an issue. Of course I also don't feel the need to replace that nut when I'm doing the tie rod end.
  7. #7 Re: Tie Rod Nut Stuck.. any suggestons?
    I never replace it unless it looks rounded off
  8. #8 Re: Tie Rod Nut Stuck.. any suggestons?
    the inner tie rod has a square part on it, for holding it still to crack the lock bolt if needed.
    if that rod and the nut spun, then its free from the outer tie rod. if so, then pop the tie rod off the knuckle and unscrew it. then put the new one to the lock nut. let the alignment shop deal with the lock nut.
  1. Car stuck in park, key isn't stuck though
    By capitalcrew in forum General Tech Discussion
    Last Post: 05-03-2012, 10:28 PM
  2. Key Stuck in Ignition and Shifter Stuck in Park
    By GRAFIX in forum General Tech Discussion
    Last Post: 02-25-2012, 02:50 PM
  3. Key Stuck
    By Iceman6669 in forum General Grand Prix Discussion
    Last Post: 01-21-2012, 01:00 AM
  4. o2 is stuck
    By Ricky21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2010, 06:48 PM
  5. How Come My Car Gets Stuck In This Vid.....
    Last Post: 12-17-2008, 02:18 AM
