Thread: Caliper Torque Specs and Brakes
Results 1 to 20 of 31
  1. #1 Caliper Torque Specs and Brakes
    Mar 2013
    Canada
    I am replacing the front brakes and rotors today, I have search the forum for the torque specs for my year which is a 2008 GP 3.8L but I can only find years from 2000-2004 and not sure if its the same specs or not. Is anybody able to give me the specs for the Caliper Bracket and Caliper bolt please, also do you recommend replacing the back ones to if they are not making any noise and I change them about 2 years ago, arent the back one only used when you are using the handbrake?
    Thanks
  2. #2 Re: Caliper Torque Specs and Brakes
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    this may sound bad but i didnt torque mine to a sertine number i just tightened untill satisfied they were tight enough
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  3. #3 Re: Caliper Torque Specs and Brakes
    Mar 2013
    Canada
    I normally don't either as I change the brakes on these 2 years ago but I think I should start doing it, any suggestions anybody of that specs I should use. Thanks
  4. #4 Re: Caliper Torque Specs and Brakes
    Our backs are roughly 70% front and 30% rear, so its takes normally alot longer for the rear pads to wear down.
    Most will change brakes when they reach around 2-3mm of pads left, new pads are roughly 10-12mm depending on brand.
    I tend to not torque those bolts because of I have seen them break off in the bracket when torque'd back to the GM specs, you are better off just going very snug and being on your way.
    If you just changed the brakes 2 years ago, either you drive alot of city and do heavy braking or you bought the cheapest pads on the market.
  5. #5 Re: Caliper Torque Specs and Brakes
    Mar 2013
    Canada
    K thanks, I know myself im a light braking but when you have your wife drive the car its a different story then LOL.
  6. #6 Re: Caliper Torque Specs and Brakes
    Mar 2013
    Canada
    So If one wants to torque it what would it be?
  7. #7 Re: Caliper Torque Specs and Brakes
    Mar 2013
    Canada
    Would anybody know if the slider pins for the calliper the one that has the rubber tip goes on the bottom of the calliper or the top? What is the rubber used for anyways? Is it used so the calliper can be rotate to the top or bottom so you can get access to the pads without removing the two sliders? Thanks
  8. #8 Re: Caliper Torque Specs and Brakes
    Just make them tight. It's never failed me.
  9. #9 Re: Caliper Torque Specs and Brakes
    i also just make them nice and tight. calipers i snug up good, caliper brackets i make good and tight. like tight. never had one back out. i used a small pipe on my ratchet for that extra leverage.
    loosen up both sliders, then pull them out all the way, clean and re grease them with brake grease. then work them in and out of the caliper to work the grease in.
    you will also want a C clamp to push the piston back in, i leave a old pad over the piston, then clamp it back in. the rears on your car, the piston turns back in.
  10. #10 Re: Caliper Torque Specs and Brakes
    Mar 2013
    Canada
    I have done the brakes before in them but I can't remember if the slider that has the rubber tip goes on the bottom or top? I guess the top right so I can swing the calliper upwards if need to.
  11. #11 Re: Caliper Torque Specs and Brakes
    i know what rubber tip your talking about, not so sure it matters where it goes, i think i put mine in the top hole tho.
  12. #12 Re: Caliper Torque Specs and Brakes
    Apr 2012
    Goderich, Ontario
    Wait, I just did my front brakes last weekend and none of the slider pins had rubber tips. Brakes work fine.
    -Paul Walker
  13. #13 Re: Caliper Torque Specs and Brakes
  14. #14 Re: Caliper Torque Specs and Brakes
    Mar 2013
    Canada
    Thanks Scottydoggs, I thought it goes on the top to, and smoke14 your brakes would work fine if you dont have them I am pretty sure they are used for so when you want to replace your pads only you can remove the bottom slider and just slide the caliper upwards and this rubber tip will help it.
  15. #15 Re: Caliper Torque Specs and Brakes
    Mar 2013
    Canada
    I received all the parts yesterday to do my brake job on the weekend, however what I realized was the brake pads inserts that clips on the calipers on top and bottom are bigger then what is on the car now. Does it matter? Should I replace them usually I do but these clips are huge? Thanks
  16. #16 Re: Caliper Torque Specs and Brakes
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Front disc brakes
    Bleeder valve, front caliper 115 in/lbs
    Brake hose caliper bolt 40 ft/lbs
    Caliper bolts 63 ft/lbs
    Caliper bracket bolts (requires loctite) 137 ft/lbs
    Rear disc brake
    Bleeder valve 97 in/lbs
    Brake hose bolt 32 ft/lbs
    Caliper bracket bolt (requires loctite) 92 ft/lbs
    Caliper bolt 32 ft/lbs
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  17. #17 Re: Caliper Torque Specs and Brakes
    Mar 2013
    Canada
    Thanks everybody for your help, I changed the front brakes and all is good.
  18. #18 Re: Caliper Torque Specs and Brakes
    Mar 2013
    Canada
    Hi everybody quick question, it been about a month now and what I have been realizing is especially when backing up from either a spot or a driveway my brakes would squeak for few seconds until either I stop or drive in reverse. It sometimes happen when going forward but it definitely happens when reversing. I just change the brakes, put new sliders, boots, rotors and pads. Pads were top of the line that I got and I lube up everything, why in the hell it's still squeaking? I even change the pads clips that you install on the calliper bracket. Noise happens only on the driverside.
  19. #19 Re: Caliper Torque Specs and Brakes
    could be the pads your using.
    or try some brake squeal stop. its a sticky spray on coating you spray on the pad backs, this holds the pads tight to the caliper piston, and the caliper, so they cant drag as long as the caliper is releasing.
  20. #20 Re: Caliper Torque Specs and Brakes
    Mar 2013
    Canada
    Every time I do my brakes in any car I always lube up the pins, the pads and the tip of the pads. I guess I can remove the front pads and reapply some more lube.
  1. torque specs are they the same for all the 3.8's ?
    By davidadams in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-23-2013, 09:37 PM
  2. Replies: 7
    Last Post: 04-19-2012, 12:44 AM
  3. brake caliper bolt torque specs?
    By mntnbiker in forum Brakes/Suspension/Chassis
    Last Post: 01-17-2011, 11:51 PM
  4. Torque specs for rear brakes please
    By 99prixgt in forum Brakes/Suspension/Chassis
    Last Post: 09-17-2008, 08:29 PM
  5. Torque specs
    By kstanko in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2008, 12:47 PM
