Thread: weird noise help. pleeeeeeeeeeeeeeeeease
Results 1 to 6 of 6
  1. #1 weird noise help. pleeeeeeeeeeeeeeeeease
    GT Level Member reesez's Avatar
    Aug 2012
    indiana
    yes I searched. My 99 GTP makes an odd noise over 30 mph and gets louder around 60. It mostly goes away when turning wheel right, prominent when turning left. Sounds like it is coming from the front left? Checked all bearing play on front and it's tight. Checked my rear and the right rear was loose so I replaced it. Not AS loud now but still there. It vibrates pretty bad sometimes cruising at speed on interstate, about medium when accelerating. When I decelerate it makes a howling noise. Would my axles make a grinding/whirring noise like this? When I had it aligned they said my axles were loose and had play in them but that was months ago. I do know that both my front strut mounts are shot, and my driver side strut bearing is seized and turning the spring when I turn. My engine and tranny mount are also blown. Any ideas are appreciated, thanks!
  2. #2 Re: weird noise help. pleeeeeeeeeeeeeeeeease
    Aug 2012
    indiana
  3. #3 Re: weird noise help. pleeeeeeeeeeeeeeeeease
    Nov 2012
    Madison
    Quote Originally Posted by reesez View Post
    Well you kind of answered your own question, probably start with the axles, strut mounts and engine/trans mounts. Might be quite a bit quieter after Just(?) those!!
  4. #4 Re: weird noise help. pleeeeeeeeeeeeeeeeease
    you got some work to do. id do the hub first, see how it goes from there, then test the rest of the front end for worn parts. lac's, tie rods sway bar, and bushings/end links.
    and change them mounts too. asap with the bad hub.
  5. #5 Re: weird noise help. pleeeeeeeeeeeeeeeeease
    Aug 2012
    indiana
    Well I was wondering if the axles cuold go bad without clicking, because I have never had one go bad without clicking.
  6. #6 Re: weird noise help. pleeeeeeeeeeeeeeeeease
    if a axles not clicking it can vibrate, like a bad U joint in a rwd car or truck, if you ever felt one of them go bad before.
  1. weird noise when off the gas ...
    By ls1racer11 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-23-2012, 09:26 PM
  2. Weird noise
    By redgrandprix77 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-18-2011, 06:15 AM
  3. weird noise
    By c32k05 in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2009, 10:47 AM
  4. Weird Noise help!!!
    By kappy332 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-20-2008, 12:31 PM
  5. weird noise
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2008, 04:17 PM
