Thread: Sway Bar replacement
Results 1 to 12 of 12
  1. #1 Sway Bar replacement
    PA
    So I took my 98 GTP to the garage for PA inspection and the mechanic said I needed a replacement sway bar. I haven't dug into it too far but I've never heard of someone having to replace a sway bar...I've heard of replacing the end links or mounting bushings but the entire sway bar seems unlikely It has some surface rust but it's not bad. Wouldn't it have to be broken or cracked to need replacing
  2. #2 Re: Sway Bar replacement
    antioch ill
    was it front or rear. And if its your rear sway bar get a gmpp with moog end links, if its front sway replace with doorman along with moog end links. You will get much better handling aswell
  3. #3 Re: Sway Bar replacement
    Arizona
    He's probably saying that cause our sway bars tend to split horizontally where the end links attach.
  4. #4 Re: Sway Bar replacement
    It's common for the sway bars to break on w bodies
  5. #5 Re: Sway Bar replacement
    ^ and the perfect excuse to upgrade to a bigger one!
    04 Comp G.
  6. #6 Re: Sway Bar replacement
    PA
    Yeah I pulled the passenger side tire and there it was a nice chunk missing by the end link so time for a replacement. Thanks for the info guys
  7. #7 Re: Sway Bar replacement
    Sep 2011
    Copperas Cove, TEXAS
    If you can get one cheap the 02 and 03 Impala (police package) has the GMPP 34MM sway bar, should be a direct fit.
  8. #8 Re: Sway Bar replacement
    GT Level Member Jakescoots's Avatar
    Spring Lake, Mi
    Dorman bar is better because it is solid and the GMPP isn't
    http://www.grandprixforums.net/how-r...3-a-66457.html
    Does removing the spare count as weight reduction?
    Badges on a car are just advertisements....Everyone already knows what it is. And if they dont, its a mystery. People like mysteries.
  9. #9 Re: Sway Bar replacement
    Feb 2010
    TN
    Go to your local JY find a impala Police cruiser that's what I did that front sway bay is huge compared to ours unfortunately the back one on it did not look any bigger than mine
  10. #10 Re: Sway Bar replacement
    Spring Lake, Mi
    Quote Originally Posted by Logan541 View Post
    GMPP rear is solid and 19mm vs a hollow 17mm bar. But solid will be less prone to breaking and the dorman will be new and new is always better. Especially because it hasn't been sitting in a junk yard for years
  11. #11 Re: Sway Bar replacement
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    The rear sway bar on our cars stock is solid. But go on summit and order a GMPP bar, it's just as strong as the dorman but lighter because it's not solid. It may break eventually but that'll be another 200k miles down the road.
  12. #12 Re: Sway Bar replacement
    Nov 2011
    NY
    Want to save money, go Dorman, biggest/best for the buck! Want best bar available then go to Summit and order the addco bars, you'll have to wait for a few weeks.
    Done!
    I have the GMPP bars front and back, installed along with moog end links and energy suspension poly bushings on the bars. But the rear needs more. I will probably upgrade to addco rear as it is the largest available.
    Good luck!
  1. Odd sway
    By buickman104 in forum Brakes/Suspension/Chassis
    Last Post: 11-23-2011, 09:29 PM
  2. best sway bar
    By BoostJunki3 in forum Brakes/Suspension/Chassis
    Last Post: 02-20-2011, 10:17 AM
  3. Help on Sway bar
    By Vetolien in forum Brakes/Suspension/Chassis
    Last Post: 03-18-2009, 12:08 PM
  4. sway bar.
    By justwhisen in forum Brakes/Suspension/Chassis
    Last Post: 11-10-2008, 02:53 AM
