Thread: Suspension Upgrade/Drop
Results 21 to 40 of 51
  1. #21 Re: Suspension Upgrade/Drop
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    So..
    Canuck Springs
    Monroe Strut Mounts
    FE3 GM Front & Rear Struts
    Reybestos Lower Control Arms
    Moog Sway Bar Links
    Moog Outer Tie Rods
    Trailing Arms (drside is bent, wbody replacements)
    Engine/Trans Mount Spacers, if i can get them otherwise poly short db's.
    Good?
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  2. #22 Re: Suspension Upgrade/Drop
    You ever plan or are you running headers ? Don't get shorter dog bones.
    Get Vinnie spacers instead.
    04 Comp G.
  3. #23 Re: Suspension Upgrade/Drop
    Oct 2011
    MI
    I have Speed Daddy Headers and Slim Fans an easy 5" of clearance.
  4. #24 Re: Suspension Upgrade/Drop
    Vinnie spacers are a better solution.
    04 Comp G.
  5. #25 Re: Suspension Upgrade/Drop
    Oct 2011
    MI
    and those are? which is betteer the spacers or dogbones?
  6. #26 Re: Suspension Upgrade/Drop
    http://www.grandprixforums.net/lower...cers-1107.html
    You put them underneath and on top of the motor mounts and to raise the engine and correct the geometry of the cv axles so when you lower it your not putting any more stress on them.
    This is the better solution then running shorter dogbones.
    04 Comp G.
  7. #27 Re: Suspension Upgrade/Drop
    Wichita
    Pretty decent drop when compared to stock GXPs. I imagine the drop would be about the same for a 97-03' GP.
  8. #28 Re: Suspension Upgrade/Drop
    Quote Originally Posted by rperry435 View Post
    canuck no longer has gxp springs available anyways
    did you contact them on this?
    04 Comp G.
  9. #29 Re: Suspension Upgrade/Drop
    Wichita
    Ooh, I wasn't aware Canuck no longer sold them. I only got my springs on sale back in August. Must've been a runnout special, they were super cheap.
  10. #30 Re: Suspension Upgrade/Drop
    Oct 2011
    MI
    yeah on the list there is no buy button lit up to click on.
  11. #31 Re: Suspension Upgrade/Drop
    Wichita
    No Bueno.
  12. #32 Re: Suspension Upgrade/Drop
    Gotcha
    04 Comp G.
  13. #33 Re: Suspension Upgrade/Drop
    Oct 2011
    MI
    okay well if thats all i need then i guess im good to order.. although its weird zzp doesnt have any anti pogo washers in black "subframe washer"..? anyone know where i can get a set?
  14. #34 Re: Suspension Upgrade/Drop
    Nov 2012
    Madison
    W-Body store
    Why didnt you go FE3 on the fronts just back?
  15. #35 Re: Suspension Upgrade/Drop
    Oct 2011
    MI
    honestly no reason, im sure if i looked up the gm# i could find it, I didnt know or at least connect the dots the compg is FE3 until just now.
  16. #36 Re: Suspension Upgrade/Drop
    Would you like the p/n
    04 Comp G.
  17. #37 Re: Suspension Upgrade/Drop
    Nov 2012
    Madison
    both delco #'s are in that Amazon post I made,I snagged the #s from rockauto.
    You are going to want to PM Vinnie about spacers, he might not have any made now.
  18. #38 Re: Suspension Upgrade/Drop
    Oct 2011
    MI
    yeah i noticed last post date... how big of deal is it to go with dog bones instead?
  19. #39 Re: Suspension Upgrade/Drop
    Oct 2011
    MI
    Im just going to go with the FE3 GM Struts. Are they worth it over the Excel-G's Supposedly listed for the FE3 Setup hypothetically speaking.?
  20. #40 Re: Suspension Upgrade/Drop
    Wichita
    Heck yes they are! FE3's are nice Bilsteins.
  1. suspension upgrade
    By CompCam21 in forum Brakes/Suspension/Chassis
    Last Post: 11-03-2010, 09:08 PM
  2. time for a suspension upgrade
    By cms3z in forum Brakes/Suspension/Chassis
    Last Post: 09-22-2010, 11:23 AM
  3. 2007 GP Suspension Upgrade?
    By 91Formula in forum Brakes/Suspension/Chassis
    Last Post: 11-19-2009, 05:41 PM
  4. 04 suspension upgrade
    By 05grndprix in forum Brakes/Suspension/Chassis
    Last Post: 03-19-2009, 12:12 AM
  5. Here I go again, suspension upgrade
    By David99GTP in forum Brakes/Suspension/Chassis
    Last Post: 09-25-2008, 02:08 PM
