Thread: Suspension Upgrade/Drop
Page 1 of 3 123 LastLast
Results 1 to 20 of 51
  1. #1 Suspension Upgrade/Drop
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  2. #2 Re: Suspension Upgrade/Drop
    Oct 2011
    MI
    Anything Im missing besides my Springs and Shorter Dogbones Ill get elsewhere?
  3. #3 Re: Suspension Upgrade/Drop
    Probably want to check your post its not showing up and just FYI your probably going to have clearance issues with shorter dogbones running headers.
    04 Comp G.
  4. #4 Re: Suspension Upgrade/Drop
    Oct 2011
    MI
    i have slim fans.. pic work now?
  5. #5 Re: Suspension Upgrade/Drop
    Nov 2012
    Madison
    Anti-pogos?....why aren't you just reusing the old boots?
    Amazon had the FE3's for like 83&85, just sayin. PIC works
  6. #6 Re: Suspension Upgrade/Drop
    Oct 2011
    MI
    I'm putting ssc springs on it.. I didn't to piss with the old struts.. Possible give them to my brother since I know his are in much worse condition
    Sent using my Galaxy SIII on Tapatalk 2
  7. #7 Re: Suspension Upgrade/Drop
    Oct 2011
    MI
    Quote Originally Posted by spazzz View Post
    fronts are cheaper then the rear.... i cant find it that cheap on amazon
  8. #8 Re: Suspension Upgrade/Drop
    Wichita
    $85 for FE3 struts? I'd grab those and get a set of GXP springs from Canuck. That's a 2.5" drop front. 2" rear.
  9. #9 Re: Suspension Upgrade/Drop
    Oct 2011
    MI
    thats a huge drop not sure if i want to go that low.... SSC says 1.7" drop. and i figured if the FE3 part number sat any lower then what i have no then thats a plus but yeah gxp springs would work no problem huh?
  10. #10 Re: Suspension Upgrade/Drop
    Oct 2011
    MI
    how good are the canuck compared to ssc?
  11. #11 Re: Suspension Upgrade/Drop
    Nov 2012
    Madison
    Quote Originally Posted by rperry435 View Post
    Same thing manufacturer distributor deal
  12. #12 Re: Suspension Upgrade/Drop
    Oct 2011
    MI
    ahh, hmm 1.7 from normal or 2.5/2 on gxp.. any pics sdgt99?
  13. #13 Re: Suspension Upgrade/Drop
    Nov 2012
    Madison
    My car is 04 comp g with the stock struts and SSC I dropped very close to 2" both front and back
    Why are you ordering from the Monte page with new control arms.
    It would be easier to just get the FE3's and SSC's, use old boots, new mounts I guess
    ACDelco 506-623 Strut Assembly for select Pontiac Grand Prix models : Amazon.com : Automotive
    http://www.amazon.com/ACDelco-506-27...++strut+506273
  14. #14 Re: Suspension Upgrade/Drop
    Oct 2011
    MI
    I was told the 06+ monte carlos were for FE3 suspension and could possibly be lower... figured they were the better choice to go with.
    506-623 are 85 a piece. not sure if they are front or rear but thats more then 70ea.. EDIT: these are rear I assume and are for FE3 and are oem.. they may be 85 but they have free shipping so i get what your saying there
    the control arms are for a 04 gtp.
    and like i said i dont want to go rent a spring compressor and fight to get those struts apart not worth my time or effect for $45 to replace and new boots will keep me from having to do that.
    canuck no longer has gxp springs available anyways
  15. #15 Re: Suspension Upgrade/Drop
    Nov 2012
    Madison
    I don't want to be difficult here but you are going to have to compress the new springs,so you'll have a compressor right there. The old ones should just blast off with an impact, Done,easy.
  16. #16 Re: Suspension Upgrade/Drop
    Exactly what I was about to type. So your still gonna need a valve spring compressor it's around $20-25 at autozone and you get your money back when you return it. It will take you 45 mins to pull off the old struts and hardware that alone is worth you reusing your old hardware and saving money.
    04 Comp G.
  17. #17 Re: Suspension Upgrade/Drop
    Coil spring compressor not valve spring
  18. #18 Re: Suspension Upgrade/Drop
    Oct 2011
    MI
    thanks for the save...didn't even think about the install process.. i know id get the money back for renting and ill just reuse the boots as well save a few bucks
  19. #19 Re: Suspension Upgrade/Drop
    Ugh your right
    04 Comp G.
  20. #20 Re: Suspension Upgrade/Drop
    Might as well honestly I doubt your boots would need to be replacing. Save some money and put it in your gas tank lol
    04 Comp G.
  1. suspension upgrade
    By CompCam21 in forum Brakes/Suspension/Chassis
    Last Post: 11-03-2010, 09:08 PM
  2. time for a suspension upgrade
    By cms3z in forum Brakes/Suspension/Chassis
    Last Post: 09-22-2010, 11:23 AM
  3. 2007 GP Suspension Upgrade?
    By 91Formula in forum Brakes/Suspension/Chassis
    Last Post: 11-19-2009, 05:41 PM
  4. 04 suspension upgrade
    By 05grndprix in forum Brakes/Suspension/Chassis
    Last Post: 03-19-2009, 12:12 AM
  5. Here I go again, suspension upgrade
    By David99GTP in forum Brakes/Suspension/Chassis
    Last Post: 09-25-2008, 02:08 PM
