Thread: Can I rewire speed sensor harness myself?
Results 1 to 20 of 25
  1. #1 Can I rewire speed sensor harness myself?
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    My passenger front wheel bearing on my 2000 GP seems to be throwing a code and the bearing was just replaced. The ABS light stays on all the time. I checked out the wiring to that hub and it appears one of the two wires are all corroded inside, I'm assuming the wire is broke where the control arm meets the subframe (common spot for the wire to break from my understanding).
    So do I need to buy a new harness or can I simply run new wires of my own? They don't seem to be anything special.
  2. #2 Re: Can I rewire speed sensor harness myself?
    they're twisted, thats about it.
  3. #3 Re: Can I rewire speed sensor harness myself?
    Sep 2012
    Clarkston, MI
    I'll just try rewiring it and see if anything changes, otherwise I'll get a new harness.
  4. #4 Re: Can I rewire speed sensor harness myself?
    If you can solder and heat shrink it to seal it from shorting out.. you should be fine.
  5. #5 Re: Can I rewire speed sensor harness myself?
    Sep 2012
    Clarkston, MI
    Yea I can do that.
  6. #6 Re: Can I rewire speed sensor harness myself?
    Sep 2012
    Clarkston, MI
    Well I tried that and it didn't help, so I'm assuming my ebcm is bad. Oh well, I don't want to drop a small fortune to get my abs working.
  7. #7 Re: Can I rewire speed sensor harness myself?
    On 2000+ Bonnevilles someone located a bad spot in their harness I think by ohming the wiring. It was literally corrosion at a connector that spread quite a way down the wires.
    If you have that silly extension harness piece ... maybe consider trying a different one or running fresh wire to the ABS connector.
  8. #8 Re: Can I rewire speed sensor harness myself?
    Pennsylvania
    What code is it throwing?
  9. #9 Re: Can I rewire speed sensor harness myself?
    Sep 2012
    Clarkston, MI
    Yes actually my connectors are corroded at both ends, from the speed sensor to the body connector. I scraped inside them and sprayed them with electrical cleaner then ran the new wires between the two.
    Autozone has new harnesses, but the picture they show does not include the body side connector, and of course the guy doesn't know if it comes with it. I'm going to have them order it and I'll have a look at it before I buy it.
    This is the picture they show:
    http://www.ebay.com/itm/Dorman-970-0...eefa1c&vxp=mtr
    The code was for the passenger front being an issue, I do not remember the code.
  10. #10 Re: Can I rewire speed sensor harness myself?
    Pennsylvania
    If it says passenger front, then it is unlikely to be the EBCM.
  11. #11 Re: Can I rewire speed sensor harness myself?
    Sep 2012
    Clarkston, MI
    Ok, so now I just need to know if that new speed sensor harness comes with both connectors or just the one in the picture.
  12. #12 Re: Can I rewire speed sensor harness myself?
    just one, you need to cut and solder it in.
  13. #13 Re: Can I rewire speed sensor harness myself?
    Sep 2012
    Clarkston, MI
    But my connector has corrosion in it on one of the prongs and in that wire, so I need a new connector.
  14. #14 Re: Can I rewire speed sensor harness myself?
    on the hub? or the harness side? that harness linked has the cars plug on it, so it plugs into the hub.
  15. #15 Re: Can I rewire speed sensor harness myself?
    Sep 2012
    Clarkston, MI
    Corrosion inside both connectors of the wheel speed sensor harness, the wiring directly from the hub is fine.
    Yes that linked wiring has the connector that goes to the hub, but I'm saying- it doesn't have the connector on the other side, going to the body- and my current connector is corroded so I can't use it.
  16. #16 Re: Can I rewire speed sensor harness myself?
    cut the plug off, wire it directly in then. if you mean the cars harness side plug.
  17. #17 Re: Can I rewire speed sensor harness myself?
    Sep 2012
    Clarkston, MI
    Well that's what I did- I cut the 2 plugs off the existing harness and ran new wires between them. I have a feeling the connectors and the little bit of existing wire that's left from the old harness in the connectors still have enough corrosion in them to where current won't flow thru them.
    So I'm saying I need new connectors also.
  18. #18 Re: Can I rewire speed sensor harness myself?
    you soldering this? if not you should be.
    strip the wires back till you have clean copper wire, new looking, not dull or brown, solder to that. use shrink wrap tubes to seal it up good too.
    when i did my maf pig tail, i had 3 inches or less of wire till i was into the main harness.
    if let go for a long time dry wire can travel a long way up the insulation.
  19. #19 Re: Can I rewire speed sensor harness myself?
    Sep 2012
    Clarkston, MI
    Yes I am soldering and using shrink wrap.
    That's my issue. The original wire that I cut that's left on the connectors is corroded inside, all of it, including the connector.
    I really should have taken pictures.
  20. #20 Re: Can I rewire speed sensor harness myself?
    i know what it looks like,( i was crapping myself as i got closer and closer to the main harness) just re do it, but strip it back till you hit clean wire. then it will be golden.
  1. Replies: 3
    Last Post: 01-06-2013, 10:53 PM
  2. 2008 Grand Prix GXP wheel speed harness install
    By dgrinnell in forum Brakes/Suspension/Chassis
    Last Post: 05-20-2012, 09:13 AM
  3. ABS Wheel Sensor Harness, HELP
    By foursixer in forum General Tech Discussion
    Last Post: 04-14-2012, 10:38 PM
  4. Harness for coolant temperature sensor
    By Duffman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-16-2011, 07:13 PM
  5. Wheel Speed Sensor Wireing harness
    By packerfanjc in forum Tires & Wheels
    Last Post: 02-16-2011, 10:09 AM
