Thread: Aluminum cradle and firmer bushing swap
Results 1 to 6 of 6
  1. #1 Re: Aluminum cradle and firmer bushing swap
    Arizona
    04+ impala fe4 police package are firmest they should have a green line around them
  2. #2 Re: Aluminum cradle and firmer bushing swap
    SE Level Member buford1972's Avatar
    Apr 2009
    Peoria, Arizona
    Thank you everyone for your help.
    Comp Cams Cam. #150 springs. roller rockers. CNC heads. 3.4" pulley. P&P Gen V. 8-rib w/belt wrap. N* & LQ4. 1" phenolic spacer. P&P/coated LIM. boost temp gauge. Aeromotive fuel rails. underdrive W/P pulley. coated TOG headers. Magnaflow cat back. Random Tech DP & Cat. balance shaft delete. built trans. Hughes converter.
  1. trans swap cradle bolt retainer clip broken
    By 98regal in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-26-2012, 01:29 PM
  2. W-body engine/tranny/cradle swap
    By gtpstyl in forum General Tech Discussion
    Last Post: 09-25-2012, 06:45 AM
  3. Cradle steel vs. aluminum
    By minichopper6hp in forum Brakes/Suspension/Chassis
    Last Post: 09-17-2009, 09:38 AM
  4. Installing Cradle (cradle alignment pins)
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-16-2008, 05:47 PM
