Thread: 06+ impala front brakes
Results 1 to 11 of 11
  1. #1 06+ impala front brakes
    iowa
    Are these a direct bolt in? If so, what trim levels do I look for? Can they be used with 16in wheels?
    87 buick gn-fmic, 3200 stall, meth injection, gt35r/76ptrim at 24psi, 204/214 cam, 60lb injectors (at 95%dc)
    .....Then there's the wife's driver
  2. #2 Re: 06+ impala front brakes
    yup, direct bolt on. and they fit under 16s.
    you use your stock caliper, the bigger caliper brackets, and the bigger rotor.
  3. #3 Re: 06+ impala front brakes
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Wrong brakes MR. Know it all..
    Thats the 2000 Monte brake upgrade that uses the stock calipers and bigger brackets.
    He's talking about the 06+ Monte/Impala brakes.
    You need the calipers, brackets, pads, rotors. Direct bolt on.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  4. #4 Re: 06+ impala front brakes
    iowa
    I was told the 2000 caliper brackets from a impala work with the stock caliper. I was under the impression the newer style impala had dual piston calipers that were a bolt on also.
  5. #5 Re: 06+ impala front brakes
    iowa
  6. #6 Re: 06+ impala front brakes
    iowa
    Better yet, has anyone ever tried this on a gp? Leaving Facebook... | Facebook
  7. #7 Re: 06+ impala front brakes
    i dont know what im talking about, apparently. i thought they were all the 12" brakes...
  8. #8 Re: 06+ impala front brakes
    Donating User Odi's Avatar
    Chicago South Suburbs
    time for you to get a w-body again.
    Quote Originally Posted by Durk Diggler View Post
    If you get drilled ebay rotors, make sure you get drilled only. I had drilled + slotted and I did not like the feedback. I changed to drilled only and they are much better.
    get plain rotors, they work the best. drilled are prone to micro cracks, slotted eat a dick in winter.
  9. #9 Re: 06+ impala front brakes
    Houston/Baton Rouge
    Fore real..
  10. #10 Re: 06+ impala front brakes
    Donating Users Durk Diggler's Avatar
    Pittsburgh
    I have this mod, they are pretty awesome for the price.
    Find a set of dual piston calipers from a 06+ W-body from ebay or a wrecking yard.
    Buy 06+ rotors and brake pads. Install, you slightly bend the brake line to accomodate.
    Durkz 04 Silver GT2
    DHP'd, Comp G'd, looking for more speed
    http://www.grandprixforums.net/zzps-new-website-2-53834.html#post678234
  11. #11 Re: 06+ impala front brakes
    iowa
    Thought so. Thanks guys.
  1. 03 gtp/ 05 impala ss Front popping sound
    By Blazin05ss in forum Brakes/Suspension/Chassis
    Last Post: 08-28-2011, 02:55 PM
  2. 07 GXP Front Brakes
    By Fireof59 in forum Brakes/Suspension/Chassis
    Last Post: 05-24-2010, 05:14 PM
  3. Front brakes
    By MikeB91 in forum Brakes/Suspension/Chassis
    Last Post: 05-20-2010, 07:48 PM
  4. ls1 brakes up front
    By stanggreg90 in forum Brakes/Suspension/Chassis
    Last Post: 04-12-2010, 12:32 PM
