Thread: Clunking noise
Results 1 to 5 of 5
  1. #1 Clunking noise
    Aug 2012
    San Antonio, TX
    Just had my struts replaced (KYB's in front and rear) and had my car aligned. When I got my car back, it is making a clunking noise when moving the wheel more than 50% of full travel. Almost sounds like metal tubing/rod that is stuck and it vibrates. It only happens during turns.
    Any ideas?
  2. #2 Re: Clunking noise
    St. Louis
    Broken front sway bar? Take a look at the sway where the endlinks bolt to it and see if it is split. Common issue.
  3. #3 Re: Clunking noise
    SE Level Member Lowdown112's Avatar
    Dec 2012
    Louisville
    I have a similar issue but its only when i go over a speed bump or something it will make a clunk noise..bothers me but nothing is broken underneath..
  4. #4 Re: Clunking noise
    Aug 2012
    San Antonio, TX
    Quote Originally Posted by FordMan77 View Post
    Would it still happen when turning the wheel when the car is not moving?
  5. #5 Re: Clunking noise
    St. Louis
    It could. My 00 GT had and end cracked and it would still pop when I turned it sitting still. My noise was from the 2 pieces of the eye at the end of the swaybar popping past each other as the sway flexed.
  1. clunking noise in right rear
    By chenango kid in forum General Tech Discussion
    Last Post: 10-13-2012, 09:26 AM
  2. clunking noise
    By jessejj79 in forum General Tech Discussion
    Last Post: 02-28-2011, 12:49 PM
  3. Clunking Noise...
    By Bedwards in forum Brakes/Suspension/Chassis
    Last Post: 01-10-2011, 09:17 PM
  4. Bad clunking noise and bad acceleration
    By ill12will8 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2010, 03:00 PM
  5. clunking noise?
    By bensett004 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-07-2009, 02:55 AM
