Thread: More ignorant brake questions from an ignorant person
Results 1 to 10 of 10
  1. #1 More ignorant brake questions from an ignorant person
    I live here. DirtDog's Avatar
    Jun 2012
    So I redid all of my front brakes three months ago. Full set up. New calipers, new ceramic pads from oreillys. Ever since then I get a squeak when I push on the brakes. I have been researching the brake sections and read thru the big bad brake forum. I lobed everything up very well with synthetic brake stuff in the packets. Any more ideas for the squeak? And the dust guard is not rubbing the rotor. First thing I checked. Also the squeak is worst in morning when dew is on them
    Sent from my pager using Morse code. ... .. ... ....
  2. #2 Re: More ignorant brake questions from an ignorant person
    Likely its just your brake pads.
    I get a squeak from my rear brakes for the first 1-3 times I hit the brakes.
    Jun 2012
    Is it cause their ceramic? The old ones which were the original factory didn't squeak but the left nasty brake dust on everything. And yes it pretty much is for the first few times I push brakes. Where all are the proper places to put the synthetic lube stuff?
  4. #4 Re: More ignorant brake questions from an ignorant person
    Maybe its the material, I'm not an expert on it.
    I'm sure the weather, being damp, type of pad and rotor come into play, but I wouldnt even worry about it.
    And when I do brake jobs, I only grease the caliper bolts/pins and the slides that the pads run on. I never grease the back of the pads.
    Jun 2012
    Will do. I guess that squeak is something to live with then.
  6. #6 Re: More ignorant brake questions from an ignorant person
    Dec 2011
    chicago
    Try different pads, I used to have the golds from advance auto and they made horrible noise. Went back, got the $12 silver line pads, no more noise.
    Jun 2012
    Its all good now...old thread sorta. Ended up having the brand new rotors resurfaced to remove that first super thin layer and that fixed the noise
    Sent from my DROID RAZR using Tapatalk 2
  8. #8 Re: More ignorant brake questions from an ignorant person
    Feb 2010
    TN
    Did you remember to clean the rotors with brake clean before you put them on and I would take the pads off clean them and relube them again
    Jun 2012
    Yea I did...dunno if this other guy did. Its probably just cause their new rotors like mine were
  10. #10 Re: More ignorant brake questions from an ignorant person
    Jul 2012
    Chicago
    FWIW, my ceramics are pretty noisy until I stop with them a couple times.
    -Carl
  1. brake upgrade questions
    By asite57 in forum Brakes/Suspension/Chassis
    Last Post: 03-15-2012, 07:22 AM
  2. Think Youtube Comments Are Ignorant?
    By SuperSport in forum The Rant Forum
    Last Post: 10-21-2010, 06:05 PM
  3. More brake questions.
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 08-10-2010, 07:24 PM
  4. Ignorant racist people
    By 04BlackComp_G in forum The Rant Forum
    Last Post: 04-20-2009, 08:41 PM
  5. Brake Questions.
    By Panther427 in forum Brakes/Suspension/Chassis
    Last Post: 12-29-2008, 09:42 PM
