Thread: 05 GXP brakes on 97-03 GTP
Results 1 to 8 of 8
  1. #1 05 GXP brakes on 97-03 GTP
    SE Level Member canadian2000gtp's Avatar
    Aug 2011
    london ontario canada
    anyone have this done? came accross a set of 05 bonneville gxp calipers and rotors the other day, and think its a good idea to swap.. specially since i bought the wheels off the same car... any input is greatly appreciated.
    00GTP, Silvermist, lowered on custom GR2 coilovers, SD air dam, GPO grilles,etc 01GPGT, Galaxy Silver, lowered on SSC springs, clear corners, glorified Special Edition SMGPFC Member #17
  2. #2 Re: 05 GXP brakes on 97-03 GTP
    Bonneville brakes are very different
  3. #3 Re: 05 GXP brakes on 97-03 GTP
    Aug 2011
    ffs im gettin mixed input.. some say yes some say no..
  4. #4 Re: 05 GXP brakes on 97-03 GTP
    Wichita
    Go for the CTSV/GT500 brake setup
  5. #5 Re: 05 GXP brakes on 97-03 GTP
    Aug 2011
    see, i would if i didnt work at a auto wreckers and get parts for next to nothing... hahahaha
  6. #6 Re: 05 GXP brakes on 97-03 GTP
    GTP Level Member buickman104's Avatar
    NYC
    They will bolt on and work just fine.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
    Quote Originally Posted by canadian2000gtp View Post
    Might as well pull them off and try them out and post results. If you get them for cheap your not losing out to much and can always sell them on the bonneville forums.
    04 Comp G.
  8. #8 Re: 05 GXP brakes on 97-03 GTP
    Aug 2011
    very true.. might juss do it this weekend if its decent enough out... i sure as hell hope they will work, i dont wanna have the gxp wheels with tiny ass brakes lmao
  1. Brembo brakes or f-body brakes? Any other choices?
    By LAST2DOOR in forum Brakes/Suspension/Chassis
    Last Post: 09-26-2013, 10:37 PM
  2. Brakes squealing even after foot is off brakes
    By GTLGDP in forum General Tech Discussion
    Last Post: 06-26-2012, 09:16 PM
  3. What brakes should i go with?
    By Whitehispanic in forum Brakes/Suspension/Chassis
    Last Post: 04-09-2009, 06:36 PM
  4. Brakes
    By dmoney01 in forum General Tech Discussion
    Last Post: 03-15-2009, 09:34 PM
