Thread: bmr trailing and lateral arms
Results 1 to 12 of 12
  1. #1 bmr trailing and lateral arms
    antioch ill
    these seem pretty expensive but ive heard good things about bmr. i recently took a corner a little hot and i slid across the road a bit due to bad tires and shafty suspension so im trying to make it better i know its a fwd family car so it will only get so good but im gonna make improvements.
    1996 - 2006 W-Body | Control Arm Packages | CAP004 - Rear Control Arm Package | BMR Suspension - The Leader in High Performance Suspension & Chassis
  2. #2 Re: bmr trailing and trailing arms
    Ocala, FL
    Quote Originally Posted by Matt Palm View Post
    Trailing and trailing arms?
  3. #3 Re: bmr trailing and lateral arms
    antioch ill
    fixed
  4. #4 Re: bmr trailing and lateral arms
    Texas
    Are you planning on doing autocross or just want better handling?
    Why spend that kind of coin when you go a cheaper yet still effective route? Personally, I have:
    OTTO strut tower bar
    GMPP front sway bar
    GMPP rear sway bar
    Aurora rear strut bar
    GMPP trailing arms
    Eibach lowering springs
    My car handles fairly well for a FWD sedan. You could go without the springs, but if you are willing to spend $500 then why not add more to the list than just trailing arms?
    85 Corvette
    01 TA
    03 Z06
  5. #5 Re: bmr trailing and lateral arms
    GTP Level Member BlownBigBlock's Avatar
    Apr 2009
    Carlisle PA
    Quote Originally Posted by txslow6 View Post
    GMPP front sway bar
    GMPP rear sway bar
    GMPP trailing arms
    Agree with list except for a few things, you're not going to find GMPP trailing arms anymore, so aftermarket is going to your choice. In regards to Eibach springs, they suck... And if you do go with the springs, don't expect your stock struts to last long with that type of drop.
  6. #6 Re: bmr trailing and lateral arms
    Dec 2008
    Lawndale, CA
    BMR makes good stuff. The trailing arms are very thick. They will rub with wide wheels that have a high offset. They usually have sales for black friday and cyber monday.
  7. #7 Re: bmr trailing and lateral arms
    tennessee
    do what you want, but kyb gr2's, eibach pros (anti pogo washers) zzp tubular trailing arms, gmpp front and rear sways, and 245/45/18's = sh**load of grip and 90mph corners not by any means setup for drag but definitely for mountain roads
    You could always check out local junkyards or Morad and get the trailing arms of a Gxp or monte SS and save some money.
    04 Comp G.
  9. #9 Re: bmr trailing and lateral arms
    Dec 2008
    Lawndale, CA
    UMI also makes a set of trailing arms.
    Here is the info for the BMR and UMI sales through 11/26.
    BMR Thanksgiving Sale - 15% OFF most BMR Suspension products - LS1TECH
    UMI Performance 15% Off Sale & Only $9.99 Shipping! 11-22 to 11-26 - LS1TECH
  10. #10 Re: bmr trailing and lateral arms
    Texas
    Quote Originally Posted by BlownBigBlock View Post
    They may not be made anymore, but you can purchase replicas of them:
    W Body Store Boxed Trailing Arm Kit - W Body Store
    85 Corvette
    01 TA
    03 Z06
  11. #11 Re: bmr trailing and lateral arms
    Donating Users RareGMFan's Avatar
    Dec 2008
    Naperville, IL
    Those aren't GMPP replicas. They're basically Doorman trailing arms. The GMPP trailing arms were tubular, not boxed.
    PREVIOUS: '89 Pontiac 6000 STE AWD (2/1376), '90 Pontiac GP SE McLaren Turbo (1/2749)
    '90 Pontiac Grand Prix STE McLaren Turbo (1/1000), '01 Pontiac GP GTP Special Edition (1/1341)
    CURRENT: '00 Pontiac Grand Prix GTP (ugh...boring regular one)
  12. #12 Re: bmr trailing and lateral arms
    Depending on what you are looking to spend/do. There's lots of options. Myself, I was sick of seeing the tinfoil lateral and toe links on these cars always being bent from tow trucks etc.
    If you dare.. search for my Regal build. It wasn't super expensive and the car definately handles better.
  1. Rear Trailing Arms
    By SlowNA06 in forum Brakes/Suspension/Chassis
    Last Post: 07-07-2010, 09:18 PM
  2. Trailing Arms
    By shawngtp in forum Brakes/Suspension/Chassis
    Last Post: 02-24-2010, 08:56 AM
  3. just an fyi--trailing arms
    By quinnp12 in forum Brakes/Suspension/Chassis
    Last Post: 02-03-2010, 12:38 AM
