Thread: Zzp lowering springs
Results 1 to 4 of 4
  1. #1 Zzp lowering springs
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Is there a difference. Between the 97-03 and 04+ Zzp springs.? I might be picking up a set and I'm not sure what option they were from Zzp on the pull down menu
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  2. #2 Re: Zzp lowering springs
    antioch ill
    same here i need more info
  3. #3 Re: Zzp lowering springs
    04+ are probably going to be longer and/or a higher rate because the car is heavier (just a smidge).
    Oct 2011
    MI
    Hmm.
  1. lowering springs
    By carl06GT in forum Brakes/Suspension/Chassis
    Last Post: 03-22-2009, 02:16 AM
