Thread: 04 Grand Prix GT sounds airplane when at speed.
Results 1 to 11 of 11
  1. #1 04 Grand Prix GT sounds airplane when at speed.
    Oct 2012
    Canada
    I have a 2004 Grand Prix GT 3.8L that sounds like an airplane when at speeds. Sound seems to be a little louder when turning as well. Car sounds normal when idling. Any ideas what this could be?
  2. #2 Re: 04 Grand Prix GT sounds airplane when at speed.
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    You have an intake?
    Take a video?
  3. #3 Re: 04 Grand Prix GT sounds airplane when at speed.
    Oct 2012
    Canada
    I will go and try to take a video now. Thanks for the quick reply.
  4. #4 Re: 04 Grand Prix GT sounds airplane when at speed.
    I live here. TLSheff's Avatar
    This is a silly question... Could it be the tires on the road?
    A video will probably help if the recorder can pick up the sound. Need to narrow down if its actually engine, trans, or if it might be tires. I had an old set and they made my car sound like a dam hummer running down the road at 45mph+ highway speeds or faster was like a dam jet engine spinning.
  5. #5 Re: 04 Grand Prix GT sounds airplane when at speed.
    Oct 2012
    Canada
    Here is a little video. You can hear the noise when turning left and while braking. I dont think it is the tires as the car just started doing this. Sorry i am new at this stuff.
  6. #6 Re: 04 Grand Prix GT sounds airplane when at speed.
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    that is a hub bearing that is bad need to replace it what way does i get louder when u turn right or left
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  7. #7 Re: 04 Grand Prix GT sounds airplane when at speed.
    Apr 2009
    Elkhart
    i would prob say if u had the cash do both fronts but really only need to replace the one that is bad at the moment
  8. #8 Re: 04 Grand Prix GT sounds airplane when at speed.
    Oct 2012
    Canada
    Seems to get louder when i turn left. Would that mean it is the drives side hub bearing?
  9. #9 Re: 04 Grand Prix GT sounds airplane when at speed.
    Rockauto.com - Timken Wheel bearings. Buy 2, replace both. You won't regret it.
    To test this, jack the car up and stabilize the car on jack stands. Grab the tire with one hand on top and one on bottom and see if you can rock it back and forth on top and bottom. If it feels loose and will rock the bearing are going out. If you can rock it left or right you may/maynot need new tie rods :P Just a check while you're there.
  10. #10 Re: 04 Grand Prix GT sounds airplane when at speed.
    Oct 2012
    Canada
    Thanks for the help guys. Went on rockauto.com and and ordered parts. I really appreciate the help.
  11. #11 Re: 04 Grand Prix GT sounds airplane when at speed.
    GTP Level Member buickman104's Avatar
    NYC
    Yup definitely hub bearing.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  1. top speed of a 2000 grand prix gt WITH govenor still intact
    By 2000grandprxgt in forum Off Topic Discussion
    Last Post: 05-14-2012, 09:36 AM
  2. 2007 grand prix dies at low speed.
    By travis56 in forum General Tech Discussion
    Last Post: 06-21-2011, 02:07 AM
  3. Replies: 25
    Last Post: 09-01-2010, 05:49 AM
  4. Six Speed Manual in a Grand Prix!
    By njbrain in forum General Tech Discussion
    Last Post: 03-30-2010, 09:10 PM
  5. Six Speed Grand Prix Video
    By njbrain in forum Off Topic Discussion
    Last Post: 10-15-2008, 01:29 AM
