Thread: Brake squeal help
Results 1 to 9 of 9
  1. #1 Brake squeal help
    I live here. DirtDog's Avatar
    Jun 2012
    So ive been talking with someone on here and im having no luck with solving my problem so i figured i would try and see if any one else had any ideas. I recently changed out my transaxles on both driver and passenger sides and replace the tie rod end links, sway bar end links, hub assembly, and the brake caliper on the drivers side to try and trouble shoot this problem but if i drive the car there is a really loud squealing noise that comes from the brake area in the front. I cannot figure out why, where, or how this noise is coming from. i ordered new rotors and brakes today to see if replacing them will help. but if anyone has had this problem befor or has any advice on what it could be please let me know. im going to upload a video link tomorrow.
  2. #2 Re: Brake squeal help
    When does it make the noise?
    On the gas or when on the brakes?
    At what speeds?
  3. #3 Re: Brake squeal help
    Jun 2012
    it makes the sound as soon as i start rolling forward....but its not constant itll like stop for a second or two then start back. If im in reverse it doesnt do it near as bad. and i dont even have to give it gas just moving forward will make it do it. I put the car in neutral and pushed it and it still makes the noise without anything running. and speeds i havent had it above 15 mph since this noise started.
  4. #4 Re: Brake squeal help
    Jun 2012
    on this page that im fixing to add a link to is the same sound mine is making but when i go forward http://www.grandprixforums.net/loud-...eak-68074.html
  5. #5 Re: Brake squeal help
    Jun 2012
    hey just want to let anyone know if your having this problem and it sounds like the video in that link that i sent i figured out the problem and its very simple and can be fixed with a house key. Between your hub assembly and the knuckle that the hub assembly mounts onto is a thin metal piece that holds the abs wiring in place. on the bottom of that metal piece is another part that just sticks out for no reason down there. Take and bend it away from the rotor chances are it prolly got bent while working on it and it was what was rubbing the rotors. any more question or want pictures let me know and ill post them
  6. #6 Re: Brake squeal help
    Ah, we see that all time in the shop, the dust shield or the brake backing plate get bent and rub on the rotor.
    Jun 2012
    Yea it was driving me crazy
    Sent from my DROID RAZR using Tapatalk 2
  8. #8 Re: Brake squeal help
    Quote Originally Posted by marines542 View Post
    im sure i asked if the dust shield was rubbing the rotor...thats that thin piece of metal with no reason for being there.
  9. #9 Re: Brake squeal help
    Jun 2012
    o haha yea i didnt know that was a dust shield. ive never seen one like that before....it doesnt even cover anything at all it just goes between the hub and steering knuckle and hold the abs wires in place. i guess i now know what it is.
  1. ARGH, The squeal!!
    By Carpepoon in forum Brakes/Suspension/Chassis
    Last Post: 08-15-2013, 01:43 PM
  2. belt squeal
    By Sandman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2011, 03:10 PM
  3. Brake squeal
    By 04GTPCOMPG in forum Brakes/Suspension/Chassis
    Last Post: 06-15-2009, 12:06 PM
  4. another brake squeal
    By drunknmunky in forum Brakes/Suspension/Chassis
    Last Post: 01-09-2009, 01:41 AM
  5. squeal
    By dbean in forum Brakes/Suspension/Chassis
    Last Post: 10-18-2008, 04:22 PM
