m1sterb0b
I had a similar problem. My dad and I took off the front 2 tires to check it out and it was the ABS mounting plate rubbing. We found out that when you turn the wheels all the way one way, that one will actually get bent a little bit. So, what we did is I turned the wheel all the way to the right, and had my dad adjust the right sides bracket until it no longer touched any moving parts (mainly the router) and then we did the same thing with the left side, and now I don't have any squeaking!
