Thread: Who is running the Strut Spring combo from ZZP?
Page 1 of 3 123 LastLast
Results 1 to 20 of 47
  1. #1 Who is running the Strut Spring combo from ZZP?
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    I am contemplating getting these, I know most of you will say go coil over but I am not looking for a serious drop just an inch or two max. I was gonna go and just do springs but with 160k miles on lil blacky I figured time for struts too. Any one got any picks of this set up?
    ZZPerformance - Drop in Strut/Spring Combo #ZZ-DRPSTSP
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  2. #2 Re: Who is running the Strut Spring combo from ZZP?
    Marysville WA
    All I need is a pic!
  3. #3 Re: Who is running the Strut Spring combo from ZZP?
    SE Level Member 98blowntwotone's Avatar
    Oct 2011
    Baldwin City, Kansas, United States
    oops.. i forgot that combo comes with the ssc's...
    1998 GTP-
    3.5 mps, p&p'd blower, HAI, AL104's, SD Headers, no res, stock mufflers, HPTuned.
    lowered on ZZP springs w/ GR2's, strut braces, poly dogbones, and poly swaybar endlinks.
  4. #4 Re: Who is running the Strut Spring combo from ZZP?
    Oct 2011
    other than my rear end being a little too high for my liking, i love the set up... lowering springs make it feel like a whole new car steering response definitely quickened and a little more nimble
    1998 GTP-
  5. #5 Re: Who is running the Strut Spring combo from ZZP?
    go to lowering thread, ssc springs.
  6. #6 Re: Who is running the Strut Spring combo from ZZP?
    Marysville WA
    I only saw the pic of the springs, but specifically of the strut and spring combo. Is it safe to assume that the end result is the same?
  7. #7 Re: Who is running the Strut Spring combo from ZZP?
    Oct 2011
    i don't have a pic but i just put the zzp lowering springs on my car.....i dropped the front end after installing the front two and was thrilled.... but then i got the back two on and was pissed... my rear end now sits higher than it did before... don't really recommend zzp's springs if that is what comes on it... but then again i have yet to talk to zzp about it, i am thinking i got a bad set or i did something wrong but idk what i would've done wrong...
    1998 GTP-
  8. #8 Re: Who is running the Strut Spring combo from ZZP?
    Jan 2012
    Philadelphia
    is it worth it to buy it? i was also thinking about it a while back i need new struts anyway
  9. #9 Re: Who is running the Strut Spring combo from ZZP?
    GTX Level Member blackflag's Avatar
    Virginia
    SSC springs, same thing.
    But seriously. Just get coilovers. When i blow these struts thats where im going
  10. #10 Re: Who is running the Strut Spring combo from ZZP?
    Marysville WA
    Quote Originally Posted by BlackFlag View Post
    What is the drop with the coilover setup from ZZP?
    Im just afraid of going to low, I know blasphemy but I just use this as my DD and dont need to go super low! Just need to delete the 4x4 look!
    ZZPerformance - Coil Over Strut Package for Wbody #ZZ-COVRSRT-WB
    I dont mind getting coilovers the price isnt whats stopping me I just hear that alot of components start to go out at that kind of a drop but i guess they are adjustable so maybe I would be fine? I just love the bolt on aspect cause it sounds super easy to just jack it up and then swap out my old set up.
  11. #11 Re: Who is running the Strut Spring combo from ZZP?
    Apr 2012
    Bancroft. Ontario, Canada
    Is it just me, or is my car about the same height about yours?? Mine's not dropped at all, but i'd love to go a lil' lower than your setup there
  12. #12 Re: Who is running the Strut Spring combo from ZZP?
    Virginia
    Quote Originally Posted by Speedy1973 View Post
    I got a little over 2" out of the drop.
    Unless your suspension components are trashed i doubt your at the same height stock.
    I feel like ssc's give it a modern factory look. Not super low, just stock looking as opposed to 4x4 status
  13. #13 Re: Who is running the Strut Spring combo from ZZP?
    coilovers will probably let you go anywhere from stock height to 4" of drop. they will just be worlds better for handling.
  14. #14 Re: Who is running the Strut Spring combo from ZZP?
    Marysville WA
    So coilovers it is I guess! Im assuming its just a simple tool to set the height and is it literally a dial by inch adjustment? So if I want a drop like a set of SSC springs how close could I get? Would lowering my car two inches cause a series of other necessary mods? I was already planning on getting the shortened dogbones but what else would I have to look for with a coilover set up with an approx two inch drop?
  15. #15 Re: Who is running the Strut Spring combo from ZZP?
    michigan
    Im actually picking up a zzp setup from a local member, but he said he didnt need to use anti pogos or dogbones/spacers on his car. Im questioning that....
  16. #16 Re: Who is running the Strut Spring combo from ZZP?
    May 2012
    Albuquerque, NM
    I'm very interested as I was thinking of replacing my struts and figured an upgrade would be due.
  17. #17 Re: Who is running the Strut Spring combo from ZZP?
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by h0wl0ngcanitbe View Post
    Coils set the height, so you are asking for pics of SSC/CM coils.....
    Spec'd at 1.6"/1.8" drop, I netted 1.1875"/.625.
    Lots more pics here.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  18. #18 Re: Who is running the Strut Spring combo from ZZP?
    depends on the the condition of other related components such as motor mounts and axles.
    Jan 2009
    Tallahassee, FL
    For that kind of drop you'd need either the shorter dogbones or mount spacers. Both do the same job.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  20. #20 Re: Who is running the Strut Spring combo from ZZP?
    michigan
    So for the advertised drop from zzp of 1.2", is it a possibility i wont need anti pogos or spacers?
  1. amp & sub combo... capacitor?
    By GTPjunkie in forum Audio, Security & Visual Electronics
    Last Post: 03-06-2010, 10:49 AM
  2. Monroe Quick Strut vs. KYB Strut Plus...definitive?
    By FRESCOLIO in forum Brakes/Suspension/Chassis
    Last Post: 09-30-2009, 05:27 PM
