Thread: Steering question
Results 1 to 7 of 7
  1. #1 Steering question
    Jun 2012
    Richburg,SC
    a few months ago I got a new rack and pinion for my 2001 grand prix, ever since I got about 3/4 of an inch freeplay in steering, went back to shop and mechanic said that's the way it was and there was no way to adjust it, anyone have a suggestion, just doesn't make sense to me that brand new parts should have such a problem...the freeplay is aggravateing to me, wife's car she said she is about got use to it, but not me
  2. #2 Re: Steering question
    HUDSON
    Try checking the steeering shaft joint that goes between the rack and the column, it is under a rubber boot.
  3. #3 Re: Steering question
    Jun 2012
    Richburg,SC
    Quote Originally Posted by QUICKSILVER462 View Post
    ok are there any adjustment in it, thanks
  4. #4 Re: Steering question
    HUDSON
    NO adjusmentsto be made, just make sure the connetion to the shaft on the rack is tight, the bolt is in place and not loose, make shure the u-joint is not loose or broken, basically you need to check all the mechanicals going to the rack to make sure there are no problems there. If somthing is bad, then that is likely the problem, if not, then you have to start checking the rack. Take a look at the rack, does it look new? or is it all dirty and greasy? If it was a reman (new) rack installed, it should still be clean, or painted all black. If a used un-remanufactureed rack was installed, the problem might be the rack itself.
  5. #5 Re: Steering question
    Donating Users
    phila pa
    hi i have the same problem even put in a new intermediate shaft and rack .though the shaft might be bad.how did you make out.have 2001 gtp.
  6. #6 Re: Steering question
    Jun 2012
    Richburg,SC
    Quote Originally Posted by ronaldgtp View Post
    man i,m just driving it like it is, wife mostly drives it and she sort of got use to it, if you find an easy fix, let me know
  7. #7 Re: Steering question
    Donating Users
    phila pa
    put back in old shaft grease it real well so far works find. had a bad dorman shaft 425-135 was real loose.
  1. Power steering question
    By Whitehispanic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2011, 03:00 PM
  2. Steering system question
    By quickster in forum Brakes/Suspension/Chassis
    Last Post: 04-07-2011, 12:10 PM
  3. question about steering rack
    By GTP Ryan in forum General Tech Discussion
    Last Post: 12-13-2010, 12:34 AM
  4. steering question
    By GTP Ryan in forum Off Topic Discussion
    Last Post: 12-12-2010, 02:33 PM
  5. power steering question please help
    By mcsddd in forum General Tech Discussion
    Last Post: 12-05-2010, 10:47 PM
