Thread: Loud reverse Squeak!!
Results 1 to 15 of 15
  1. #1 Loud reverse Squeak!!
    Sep 2012
    United States
    Ok guys so here is the problem... My car will make a loud squeal only in reverse and it comes from the right font of the car. First off i thought it was the bearing so I changed that today and when i was done and went for a test drive its smoother then ever driving forward and making turns. But as soon as i go in reverse it squeals even louder!!!? So i have some other ideas but i would like to know if anyone else had any suggestions or have experienced this same issue. The car is a 2004 Grand Prix.
  2. #2 Re: Loud reverse Squeak!!
    post a vid if you can.
  3. #3 Re: Loud reverse Squeak!!
    brakes?
  4. #4 Re: Loud reverse Squeak!!
    Sep 2012
    United States
    I will have a video up shortly with the noise.
  5. #5 Re: Loud reverse Squeak!!
    Sep 2012
    United States
  6. #6 Re: Loud reverse Squeak!!
    sounds like your pads are worn down to the squealers. inspect your brakes.
  7. #7 Re: Loud reverse Squeak!!
    Sep 2012
    United States
    Brakes are fine. Thats why this is so puzzling to me. Since i just changed the bearing and it was doing this before hand also tells me its not the hub so that leaves it to the cv shaft or something internal there but its just a thought.
  8. #8 Re: Loud reverse Squeak!!
    It can be that the pads you have are cheap and are making the sound.
    Also maybe its the park brake shoes/pads rubbing on the inside of the rear rotor.
  9. #9 Re: Loud reverse Squeak!!
    have you greased the caliper slider pin/bolts? or where the pads sit on the caliper bracket? ( the metal plate area)
    if not take them apart, clean them up with brake cleaner, inside the caliper as well, grease the pin/bolts with synthetic brake grease. work it in good till they slide in and out nice and smooth.
    auto zone sells it in ketchup like packets at the counter.
    put it all back together and that should help.
  10. #10 Re: Loud reverse Squeak!!
    Sep 2012
    United States
    ok i will try it out and see what happens. I was just thinking if it was the brakes i would hear it more then just in reverse.
  11. #11 Re: Loud reverse Squeak!!
    sounds like the pads are dragging the rotor.
    if they squeak when coming to a stop as well the greasing can fix that too.
    they seemed to squeak some when you came to a stop going forward as well.
  12. #12 Re: Loud reverse Squeak!!
    I live here. DirtDog's Avatar
    Jun 2012
    this is the same noise mine is making now but when i go forward and it didnt start till i did some front end work on my car. did you ever find a fix for this?
  13. #13 Re: Loud reverse Squeak!!
    Jun 2012
    hey man dunno if you got your squeal fixed yet or not...i was having the same problem and it turned out to be a metal piece between the hub and steering knuckle that the hub goes into. Just bend that piece away from the rotors
  14. #14 Re: Loud reverse Squeak!!
    SE Level Member jamez74's Avatar
    Jan 2013
    Medicine Hat, Alberta
    Raising this thread from the dead, I had this same problem, turned out it was the bracket that holds the wheel sensor. Bent it back a touch and problem solved.
  15. #15 Re: Loud reverse Squeak!!
    Feb 2013
    37.295091, -121.930053
    a zombie thread RUN AWAY RUN AWAY
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  1. GXP Transaxle Squeak
    By chevyguy04 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-25-2015, 04:43 PM
  2. Pulley Squeak
    By Adidasdude1989 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-03-2012, 07:25 AM
  3. want to know what my squeak is
    By Fedewaj in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2010, 08:59 PM
  4. Got a squeak that won't go away...
    By Sandman in forum Brakes/Suspension/Chassis
    Last Post: 10-02-2009, 06:12 PM
  5. loud squeak drivers side on left turns only
    By jsveen in forum Brakes/Suspension/Chassis
    Last Post: 05-26-2009, 08:20 PM
