#1
5th brake hose "hard line" solution ~$6
Post Thanks / Like - 1 Thanks, 1 Likes, 0 Dislikes
#2
Re: 5th brake hose "hard line" solution ~$6
I live here.
09-24-2008
If you pull this off I hope you will post in detail how you did it all. The rubber line to the caliper cant really be avoided as you need something with flex to allow for the wheel travel, but the rest of it, I dont see why you couldnt use hard lines.
#3
Thanks with the 12" line and union its looking promising. I will post with step by step pictures. The added bonus of having Goodrich lines already on too. Looking to do this on Friday night.
Hopefully my brakes will be rubber hose free!
#4
Done...no more rubber hose. Updated the op.
#5
I live here.
09-27-2008
Dude that is fantastic work. Thank you for posting this up and for seeing an area of improvement and pursuing a solution. I hope this makes it into the How To section as it certainly needs to be there.
#6
Off topic I know but did you have to shave down the ribs on the Vette Caliper to make it fit under stock wheels?
Cheap, Fast, Reliable... you can only pick two
#7
GTP2K1
YGPM
I saved the instruction in a word file but i hope it does make into the how to section. I had this idea back January of this year. I am very pleased with the way it came out. Thanks.
#8
GXP Level Member
10-06-2008
#9
I live here.
10-06-2008
Blown97
Great info!!
If the information is helpful, dont forget to give thanks or use the reputation to give recognition for great work and contributions.
#10
GTP Level Member
11-18-2008
So how did this impact your braking? Does it feel any better? Is there rubber left anywhere else in the system?
2000 NavyBlueMetallic GTP Coupe
HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
#11
There was not that much of an impact or improvement to the braking performance that i could notice. I was running C5s at the time. It feels better knowing there is no chance of failing an unserviceable rubber brake hose.
To this day no leaks anywhere and its great having one less thing to worry about.
#12
GTP Level Member
05-03-2013
Hope this helps when i do my front brake lines
Gremlins always seem to show up in pairs, or groups of three with our cars...
#13
apierce1289
Still running strong and leak free...
#14
I live here.
2002 Grand Prix GT N/A 127k - Same as 06 Plus: Trans Cooler, DIY Aux Input, LED lighting, Suspension Upgrades, Tint, Retrofits. Sold.
