Thread: How to install the front sway bar on a Grand Prix the easy way!
Results 1 to 10 of 10
  1. #1 How to install the front sway bar on a Grand Prix the easy way!
    GT Level Member Z28's Avatar
    Oct 2008
    Omaha, NE
    I've driven my grand prix without the front sway bar for over a year and decided to finally get a new one.
    I knew this would be a biatch to do because it was biatch to get out. So after struggling for 10-15 minutes trying to put in in through the passenger side:
    1. Take the sway bar under the vehicle with you.
    2. While underneath the center of the car, put the driver side in first, push it through an extra foot or so obviously, then slide it through to the passenger side.
    3. You may need to remove the passenger side tie rod end.
    Took me about 1 minute to get it through this way.
    Make sure you have a ratcheting wrench for those dang bolts that hold the bushings in place. They are a godsend.
  2. #2 Re: How to install the front sway bar on a Grand Prix the easy way!
    If you want to save time, lower the rear of the subframe about 2 inches. As for sliding the bar in.. I've done a lot of them and never had issues getting the bar in place.. it's only the center bushing bolts that are tight to the body.
  3. #3 Re: How to install the front sway bar on a Grand Prix the easy way!
    Grand Island, Nebraska
    Hey another nebraska guy! are you the guy that knows brock?
    sorry off topic
  4. #4 Re: How to install the front sway bar on a Grand Prix the easy way!
    Oct 2008
    Omaha, NE
    Quote Originally Posted by JoRoW99 View Post
    sorry off topic
    Ya I know bro....he shot this video of me
    Z28 vs Slowbra - YouTube
  5. #5 Re: How to install the front sway bar on a Grand Prix the easy way!
    I was at youre house with him that one time and we watched fast and furious haha.
  6. #6 Re: How to install the front sway bar on a Grand Prix the easy way!
    SE Level Member NewBoost1997's Avatar
    Jul 2010
    Minnesota
    I just flipped my sway bar and replaced bushings yesterday. I lowered the cradle on the rear side, unbolted the sway links, unbolted the bushing mounts (be really careful not to break the bolts off) take off front passenger tire and slide it out that way. Took me all about 10 minutes to get it out. I did it at work do I had a lift which made it easier. And then when putting it back make sure to put the bolts in slowly and in"criss cross pattern". Don't tighten one then the other and so on. You'll bind them up and then you are screwed. Use anti-seize on the bolts. It helps a lot.
    **edit. Sorry read post wrong. This is how I did it
  7. #7 Re: How to install the front sway bar on a Grand Prix the easy way!
    Oct 2008
    Omaha, NE
    Quote Originally Posted by NewBoost1997 View Post
    I guess my car is just a ***** then, cuz it took me probably 20 minutes to get it out, maybe more. Had the same struggles putting it in, till I figured this out, then it was cake.
    Oh ok, small world!
  8. #8 Re: How to install the front sway bar on a Grand Prix the easy way!
    SE Level Member SLICK98's Avatar
    Jul 2010
    erie,pa
    Just installed new dorman bar, took me a hour to take out, but had to drop cradel 2 inches to install. The car does handle better....
    1998 GP Daytona Supercharged
    1989 GP SE Daily driver
  9. #9 Re: How to install the front sway bar on a Grand Prix the easy way!
    GT Level Member Jakescoots's Avatar
    Spring Lake, Mi
    Does removing the spare count as weight reduction?
    Badges on a car are just advertisements....Everyone already knows what it is. And if they dont, its a mystery. People like mysteries.
  10. #10 Re: How to install the front sway bar on a Grand Prix the easy way!
    CT
    Like stated, drop the rear subframe and you'll have room. I did mine before and I had to man handle the thing to get it in there but it shouldn't be a huge issue.
    2001 GTP - 3.4" pulley, Headers, welded in flowmaster mufflers, Tune, Intake, SSC/AGX, Engine/Trans mount spacers, GMPP F/R Swaybar, 17" Rims, Built trans: 3.29 gears, 2500 stall, ect ect (built by Billboost)
  1. 87 to 03 grand prix front sway bar and gas door :)
    By sasquatch094 in forum Wanted To Buy - Parts
    Last Post: 02-26-2012, 12:26 PM
  2. Which other front sway bars will fit 98 Grand Prix
    By spenc938 in forum Brakes/Suspension/Chassis
    Last Post: 03-16-2010, 10:06 PM
  3. Front Sway Bar Install Issue
    By rileystanek in forum Brakes/Suspension/Chassis
    Last Post: 07-12-2009, 11:12 PM
  4. How to install new front speakers on a 97 Pontiac Grand Prix?
    By GothTP in forum Audio, Security & Visual Electronics
    Last Post: 07-01-2009, 07:59 AM
