Thread: wont steer
Results 1 to 20 of 27
  1. #1 Re: wont steer
    you need to get the car up on ramps, or how ever, and start the car, with it running get under it and watch where its leaking from, if you have someone there who can turn the wheel back and fourth that will make it leak more.
    if your leaking from the boots, (at the ends of the rack) just get a new rack.
    could also be from one of the lines as well.
    or the pump its self.
    if need be, clean the engine top and bottom,( and the rack and trans) then start looking again. and a clean engine is nicer to work on too.
  2. #2 Re: wont steer
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    ok thanks for the help and ill check it out on tommorow and if i need more help ill put it on here
  1. wheel hop/torque steer
    By Cobras 98 Prix in forum Brakes/Suspension/Chassis
    Last Post: 12-06-2011, 08:34 PM
  2. noise when i steer
    By mezzoni in forum General Tech Discussion
    Last Post: 03-24-2010, 10:29 PM
  3. Torque Steer?
    By jdkhunter in forum Brakes/Suspension/Chassis
    Last Post: 04-08-2009, 04:07 PM
  4. can you say torque steer?
    By 99gpse in forum Off Topic Discussion
    Last Post: 03-30-2009, 05:18 PM
  5. Hard to steer left
    By bronzegp in forum General Tech Discussion
    Last Post: 03-05-2009, 07:37 PM
