Thread: 2007 Grand Prix rear brake pad replacement
Results 1 to 6 of 6
  1. #1 2007 Grand Prix rear brake pad replacement
    Jul 2012
    Anyone have any information on replacing rear brake pads on this? I am hearing some concerns on how to take the e brake cable off and putting it back on. Not sure if the model makes a difference?
  2. #2 Re: 2007 Grand Prix rear brake pad replacement
    You should not have to touch the cable I believe.
    Just remove the caliper, then the bracket, remove the pads and rotor, new rotor on, then your calipers are a screw in style, so you'll have to take a big pliers or somthing and stick it in the 2 spots on the piston and turn it back in. Grease the slides and pins and bolt it back together.
    Apr 2012
    rhode island
    I would go rent the tool from autozone or advance to screw them in. I wouldnt risk breaking something with the pliers. But u shouldn't have to worry bout the ebrake. Just make sure it's not engaged when changin the pads out
  4. #4 Re: 2007 Grand Prix rear brake pad replacement
    SWPA
    Why rent an $8 tool that you could buy and never have to source again?
    And no, you don't have to touch the cable. I did my rear pads and rotors in literally 15 minutes. They are cake work.
  5. #5 Re: 2007 Grand Prix rear brake pad replacement
    Apr 2012
    rhode island
    that $8 tool is crap, I'm talking about the real caliper compressor, which is 10xs easier to use
  6. #6 Re: 2007 Grand Prix rear brake pad replacement
    SWPA
    If you know what you are doing, the $8 tool works perfectly fine.
  1. 2004 Grand Prix rear suspension squeeks while brake applied
    By eriklynden in forum Brakes/Suspension/Chassis
    Last Post: 06-06-2012, 09:48 AM
  2. 06 Grand Prix rear brake help needed
    By Adam Taylor in forum Brakes/Suspension/Chassis
    Last Post: 04-09-2012, 10:53 AM
  3. 2002 Grand Prix Rear Disk Brake Hub Assembly Removal
    By mtsav8or in forum How To Write-Ups/Tech Tips
    Last Post: 07-18-2011, 07:45 PM
  4. 2007 Grand Prix Strut Replacement
    By uibob7 in forum Brakes/Suspension/Chassis
    Last Post: 03-15-2010, 07:30 PM
  5. 2002 Grand Prix - Right Rear Brake Leak
    By johngandersonjr in forum Brakes/Suspension/Chassis
    Last Post: 12-18-2008, 09:43 PM
