Thread: noise from front end
Results 1 to 8 of 8
  1. #1 noise from front end
    Jul 2012
    chicago
    grand prix makes a clunking noise when hitting bump and low speed turns. Any Ideas?
  2. #2 Re: noise from front end
    ball joint, tierod, sway bar
  3. #3 Re: noise from front end
    Jul 2012
    chicago
    Thanks, you don't think it would be the struts (185,000 miles) and never replaced
  4. #4 Re: noise from front end
    Jul 2012
    chicago
    Thanks Had the tie rod and sway bar replaced last year. You don't think it could be the struts never replaced (185,000 miles)
  5. #5 Re: noise from front end
    Could be struts or strut mounts or ball joints.
  6. #6 Re: noise from front end
    GT Level Member courtney kiesow's Avatar
    Jul 2012
    its prolly the sway bar...i had to replace mine not that long ago or ball joint
  7. #7 Re: noise from front end
    I would say struts and mounts.
  8. #8 Re: noise from front end
    GT Level Member Toms04compg's Avatar
    Michigan
    I had a similar problem , i did replace front with kyb mounts blah blah inspect them but my hydraulic motor mount was effffed so it was like metal on metal. Replaced and fixed. At 185k if you assume they havent been changed your mount almost certainly hasnt been changed. GL
  1. Front End Noise
    By dlsr in forum General Grand Prix Discussion
    Last Post: 07-11-2012, 12:52 AM
  2. Front end noise
    By nikkigpgt00 in forum General Tech Discussion
    Last Post: 09-13-2011, 07:17 AM
  3. Front end noise
    By GTP2188 in forum Brakes/Suspension/Chassis
    Last Post: 02-22-2011, 01:06 PM
  4. front end noise, what else...?
    By Jakegday in forum General Tech Discussion
    Last Post: 07-30-2010, 08:22 PM
  5. front end noise, hub?
    By hourang in forum Brakes/Suspension/Chassis
    Last Post: 02-01-2010, 11:17 AM
