Thread: zzp strut tower brace install
Results 1 to 15 of 15
  1. #1 zzp strut tower brace install
    antioch ill
    how difficult is to install the zzp strut tower brace and is it worth it?
  2. #2 Re: zzp strut tower brace install
    front takes no time, rear is a PITA.
    but both can be a major PITA if they need to be ground out a little.
  3. #3 Re: zzp strut tower brace install
    antioch ill
    what do you mean ground out
  4. #4 Re: zzp strut tower brace install
    Antioch, IL
    grind. matt go in the chat ull get your responses in seconds
    2009 Challenger SRT8
    Expert at being gay.
  5. #5 Re: zzp strut tower brace install
    sometimes the strut towers have already wandered so far apart or together that you need to enlarge the holes in order to mount the things.
  6. #6 Re: zzp strut tower brace install
    antioch ill
    hopefully thats not my case i mean its got just under 33k miles
  7. #7 Re: zzp strut tower brace install
    Antioch, IL
    Matt mine has 216k my gmpp stb went on with no problems, I wouldnt worry
  8. #8 Re: zzp strut tower brace install
    Ocala, FL
    Grinding the holes a little doesn't take long if you have to. Just means opening the holes up a tiny bit if you have to.
    Rear also isn't really that bad, shouldn't take more than ten minutes.
  9. #9 Re: zzp strut tower brace install
    GTX Level Member crbquist's Avatar
    Massachusetts
    My ZZP front installed no problem. Took literally 5 minutes.. The rear on the other hand.. well, you get the idea...
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  10. #10 Re: zzp strut tower brace install
    SE Level Member Aeroheadcww's Avatar
    Williamsburg, Ky
    No one told you if it was worth it yet, my answer is a definite yes if you drive the car hard like I do. It really stops a lot of the lateral bouncing and rebound. If you don't notice stiffer cornering then you have other problems, hubs, ball joints bushings etc. I have both bars from ZZP and had no problem installing them. The rear for an 04+ has some course adjustment that may have made it easier. Just an FYI, after 80k miles replacing the hub bearings made the biggest difference in how my car handles. Also, gear wrenches help with the rear install
    _____________________________________________
    '05 CompG - 3.6 Pulley, ZZP PCM, K&N drop in, Customized SD Headers, TEP Street/Strip tranny, ZZP STBs, ZZP Coilovers, GXP front brakes
    Bunnell, FL
    Rear is easy remove the speaker covers and six by nines and you'll get allot more room
    I'm a Sex Offender
  12. #12 Re: zzp strut tower brace install
    antioch ill
    so im reviving this thread to get more answers im thinking about getting this. would it help if i went lowered and stop some pogo?
  13. #13 Re: zzp strut tower brace install
    Your over thinking this..buy it. No it won't have any more effectiveness if your lowered opposed to if you keep it like it is now. It will help w/ body roll. It's a cheap effective suspension upgrade.
    04 Comp G.
  14. #14 Re: zzp strut tower brace install
    Donating User Odi's Avatar
    Chicago South Suburbs
    thats swaybars. STB does pretty much nothing to a w-body, it should be the last upgrade.
  15. #15 Re: zzp strut tower brace install
    antioch ill
    im probally still going to buy it considering its only like 70 bucks and eventually upgrade everything else once my struts go out
  1. Strut Tower Brace is it worth it?
    By asite57 in forum Brakes/Suspension/Chassis
    Last Post: 01-16-2013, 02:56 PM
  2. WTB: Rear strut tower brace
    By Pontiac Man in forum Wanted To Buy - Parts
    Last Post: 02-19-2012, 12:44 PM
  3. Strut Tower Brace
    By stlmo_gtp in forum Brakes/Suspension/Chassis
    Last Post: 07-19-2009, 06:38 PM
  4. Strut tower brace
    By bkaab in forum Brakes/Suspension/Chassis
    Last Post: 01-29-2008, 11:15 PM
