2006 grand prix gxp right rear brake makes a clicking noise when brakes are applied pulled wheel off and inspected brake pads and rotors nothing wrong has anyone had this problem ?
BAd pads?
Are they cracked?
Made they are not the right size and are loose in the caliper and clank around when you apply the brakes.
same issue with mine, a 2004GTP. i could not come up with an answer either so i had firestone check it out and the determination was made that my left rear caliper was leaking and basically about to fail. i confirmed this later by another visual inspection. autozone sells remanned calipers for $90 + $48 core charge. companies like firestone have a policy in place where they have to replace both at the same time; couple that with labor and you're looking at a grand. best bet is to get the remans and do it yourself, then get a $79 brake flush and the bleed will be included in the service.
