Thread: replacement ABS Harness?
Results 1 to 8 of 8
  1. #1 replacement ABS Harness?
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Some how my passenger side front harness started rubbing on my crank pulley and rubbed the line all the way to the wires. Lucky it still works fine, but I'd rather get a new line.
    Is there a replacement? and I know it snaps into the wheel bearing, but where does the other end go?
    Thanks
    Steven
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  2. #2 Re: replacement ABS Harness?
    I know dorman sells some of it. Unsure how much.
    Delco also sells a pigtail kit with a fair bit of wiring.
  3. #3 Re: replacement ABS Harness?
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    I beleive the other end will have to be cut and spliced but im not positive.
    Heres the ones rockauto has for replacment
    1998 PONTIAC GRAND PRIX ABS Wheel Speed Sensor Connector
  4. #4 Re: replacement ABS Harness?
    Must be cut and spliced in.
  5. #5 Re: replacement ABS Harness?
    Houston/Baton Rouge
    Thanks guys...
  6. #6 Re: replacement ABS Harness?
    Houston/Baton Rouge
    Well, it looks like this connector can be used for lots of things. haha
    12102747 | eBay
  7. #7 Re: replacement ABS Harness?
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    try the boneyard ---- the harness you're looking for has two ends with the other end being up near the underhood fuse box. I've got a front set sitting in a box someplace, just in case.
  8. #8 Re: replacement ABS Harness?
    Houston/Baton Rouge
    Good idea, might try that this weekend.
    Should be fine of a regal, because there seems to be many grand prixs at the one I go too.
  1. Do I need a wiring harness?
    By cyclones in forum Audio, Security & Visual Electronics
    Last Post: 03-30-2011, 07:46 AM
  2. Need some help, wiring harness meltdown! have some harness swap questions for a guru
    By pureroundcircle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 09:23 PM
  3. gt to gtp do they have same harness
    By smooth1lol in forum Off Topic Discussion
    Last Post: 05-01-2010, 11:50 AM
  4. Engine Harness Replacement
    By grandprixgtcv3 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-19-2009, 01:04 AM
  5. Afc 2.0 ext harness
    By zexed99gt in forum PCM Tuning
    Last Post: 12-08-2008, 09:30 AM
