Thread: new struts?
Results 1 to 6 of 6
  1. #1 new struts?
    GT Level Member des19's Avatar
    May 2011
    Ontario
    I am looking to lower my car. Is it absolutely necessary to install new struts when going with 1.5 inch lowering springs? My 04 gtp only has 60k miles on it. Struts should last much longer than that no?
    Which struts would be the best replacement for comp g struts?
  2. #2 Re: new struts?
    Omaha, NE
    They're not REQUIRED, but reccomended since lowering springs will shorten the life of your stock struts.
    I would advise KYB GR2 or Excel-G struts for lowering springs. The 2 models are the same, but the Excel-G "replaced" the GR2's.
  3. #3 Re: new struts?
    Jul 2010
    upstate NY
    I had to do all the struts on my 05 at 70K. So I advise to do them with the spring swap.
    Also by 95K I started getting tire wear and had to put in front bearings which stopped it. So they were cheaping out parts by 05.
  4. #4 Re: new struts?
    Jun 2012
    michigan
    how good are the KYB GR2/Excel G?
  5. #5 Re: new struts?
    Jul 2010
    upstate NY
    I have 30K+ miles on them and they are doing great. No noticeable loss of damping but probably softer than when new. Well matched to the stock GT suspension. However, they are not sport struts. When I first installed them I thought they should have been valved tighter. So, if you are looking for high performance dampers, look elsewhere.
  6. #6 Re: new struts?
    Dec 2008
    Lawndale, CA
  1. Do I need new struts?
    By Korben in forum Brakes/Suspension/Chassis
    Last Post: 04-04-2012, 07:12 PM
  2. Struts
    By gunsn88 in forum General Grand Prix Discussion
    Last Post: 01-16-2012, 08:31 PM
  3. Struts for 04 GTP
    By ionroller in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2010, 12:43 PM
  4. struts
    By rharper33 in forum Brakes/Suspension/Chassis
    Last Post: 09-28-2009, 12:17 AM
  5. New Struts
    By Bigbm80 in forum Brakes/Suspension/Chassis
    Last Post: 07-12-2009, 11:55 PM
