Thread: Want to lower the GXP.
Results 1 to 16 of 16
  1. #1 Want to lower the GXP.
    Rapid City, SD
    Ok so got an 08 GXP...I want to lower it. Been looking around for coilover kits not really finding anything for my car. What is the best option anyone has found for lowering a Grand Prix and any links would be appreciated. I dont want any junk micky mouse set ups either. Id like to keep it under $1k
    Thanks
  2. #2 Re: Want to lower the GXP.
    Jul 2008
    sumter,south carolina
    02 GTP with mods 05 GP for DD
  3. #3 Re: Want to lower the GXP.
    Wichita
    Get Intrax springs.
  4. #4 Re: Want to lower the GXP.
    does the GXP have the same suspension as the regular grand prix? im not sure you can swap the goods like that.
  5. #5 Re: Want to lower the GXP.
    Dec 2008
    Lawndale, CA
    GXP's have bilsteins already so the struts can handle a lowering spring. They also already sit a little lower than a regular 04+ grand prix. I do know that SSC makes lowering springs that seem to perform well for the GXP. There are not a lot of mods available for the GXP. I am pretty sure that there are no coilover set ups. Eibach also makes springs. I'm not sure how they ride or perform.
  6. #6 Re: Want to lower the GXP.
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    it might sit to low in the front if you use regular lowering spings from a 04+ gp, cus your gxp is a v8 alot heavier in the front than a normal gp
  7. #7 Re: Want to lower the GXP.
    Wichita
    d@mned LS4's, the only LS engine with practically no aftermarket support.
    Chop the springs!
  8. #8 Re: Want to lower the GXP.
    Arizona
    I have a gxp as well...if I use ssc springs only will I be ok? I don't want to mess up any other suspension parts. I had a Supercharged Coblat with Eibachs only and had no issues at all. Why is the GP different?
  9. #9 Re: Want to lower the GXP.
    Feb 2010
    ohio
    u have a v8 heavier car the a v6 springs gona prolly sit way lower in the front then the rear might even be to low in the front that will cause problems
  10. #10 Re: Want to lower the GXP.
    Jun 2010
    ontario
    Quote Originally Posted by imdaman3 View Post
    i was reading up and the GXP is the same weight as the GTP basically, the article i read mentioned what they changed but i forget, i know the GXP has an aluminum subframe and they did some weight reduction to even out the front end's weight, i'll look for the article...
    2005 Pontiac Grand Prix GXP ​Stock
    1997 Pontiac Grand Prix GTP loaded with lots of goodies
  11. #11 Re: Want to lower the GXP.
    Quote Originally Posted by gleivas View Post
    because its a completely different car with some completely different issues.
  12. #12 Re: Want to lower the GXP.
    Dec 2008
    Lawndale, CA
    You will be fine with SSC springs. Guys on ls1tech like the ride of the SSC on the GXP. You can go there and find out more info.
  13. #13 Re: Want to lower the GXP.
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Kinda late on the reply man..
  14. #14 Re: Want to lower the GXP.
    Jun 2010
    ontario
    lmao opps, didnt realize the date, my bad, no use on reviving this dead thread
  15. #15 Re: Want to lower the GXP.
    Quote Originally Posted by mikeygan17 View Post
    if you have solid info on something like that just start a new thread on the topic.
  16. #16 Re: Want to lower the GXP.
    Closed
  1. Want to lower your car? Look in here!!
    By Bio248 in forum Brakes/Suspension/Chassis
    Last Post: 11-21-2018, 12:33 PM
  2. About the Lower intake & S/C
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-05-2009, 03:39 PM
  3. how to lower?
    By 89prix in forum Brakes/Suspension/Chassis
    Last Post: 10-24-2008, 07:17 AM
  4. Lower
    By 98GPGT in forum Brakes/Suspension/Chassis
    Last Post: 10-14-2008, 07:45 PM
  5. Lower KR ?
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2008, 09:04 PM
