Thread: Rear Passenger Strut Tower (WTF)
Results 1 to 20 of 26
  1. #1 Rear Passenger Strut Tower (WTF)
    Banned
    Oct 2013
    Moorhead, MN
    Dude. I'm gonna die if I ever do drive this car again...
    They took the studs out of the rear passenger strut cap, somehow, and replaced it with 10mm flange bolts (12.9).
    Probably a lazy strut replacement because they couldn't get clearance over the stud in the trunk?
    I know this because I was TRYING to install a strut tower brace (with Don's brackets) , but I can't with this setup...
    What do? Longer bolt and be okay with it?
    Order 3 10mm studs and apply red loctite to the lowers?
    Yes, I know there's rust. Yes, I removed one of the bolts after I finished crying.
  2. #2 Re: Rear Passenger Strut Tower (WTF)
    Banned
    Oct 2013
    Moorhead, MN
    Also, shouldn't there be a "stopper" on the bottom, threaded from the outside?
    Then a 10mm locknut fastened to the top?
    Something like this?
  3. #3 Re: Rear Passenger Strut Tower (WTF)
    Banned
    Oct 2013
    Moorhead, MN
    Or order a new strut cap from RockAuto?
    I'm not sure if I have the mechanical skill to do Struts yet.
  4. #4 Re: Rear Passenger Strut Tower (WTF)
    The bolts are "riveted" into the mount and then a nut from the top locks it into place.
    This looks like someone has bolts going down into the wheel well on the other 2 holes, I would just do the same for the 3rd for now until it absolutely necessary to replace the top mount.
  5. #5 Re: Rear Passenger Strut Tower (WTF)
    replacing the top mount would take 3 hours of your time.
    you'll need a spring compressor and an impact.
  6. #6 Re: Rear Passenger Strut Tower (WTF)
    Banned
    Oct 2013
    Moorhead, MN
    There are threads in the mount. (M10 x 1.5)
    This won't cause any damage, as studs operate differently than bolts, will it?
    I'd like to replace with a 10mm stud. I'll have to replace that bolt anyways to be able to get Don's brace installed.
  7. #7 Re: Rear Passenger Strut Tower (WTF)
    I've seen people run a bolt up through the mount and use a nut on the other end to hold a strut mount in place, Bolts can break so it is a quick and easy solution, I don't see anything wrong with it (and a little blue loctite). Especially if you have been running around with just 2 out or 3 mounting bolts bolted down.
  8. #8 Re: Rear Passenger Strut Tower (WTF)
    Feb 2013
    37.295091, -121.930053
    are you talking about all 4 or just 2?
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  9. #9 Re: Rear Passenger Strut Tower (WTF)
    i was giving you extra time. i would pop that one strut off, change the top hat and slap it back in the car in under an hour. i've done it a few times.
  10. #10 Re: Rear Passenger Strut Tower (WTF)
    I would replace the mount or get longer bolts. Never seen bolts back there.
  11. #11 Re: Rear Passenger Strut Tower (WTF)
    Banned
    Oct 2013
    Moorhead, MN
    I took one of the bolts off (out of disbelief).
    It was a m10 x 20 and didn't even reach the end of the ####### strut mount threads.
    I replaced them with black oxide flange bolts which already had a locking compound applied to it (via manufacture).
    It's very strange, and it was only done to one tower (rear passenger side). I'm trying to piece it together.
    As per the rest of the maintenance done to this vehicle (previous), this is actually up to par with some of the other ridiculous lazy #### done to this car.
    I'm guessing whoever did the strut replacement (1 strut?) didn't want to fight with the ZERO trunk clearance that the studs involved, so he just did it this way.
    It's clear now that the guy who sold it to me just threw a bunch of #### together to make the car look good to sell.
    An example of yet another surprise I found yesterday. I trying to get the passenger front fender to line up, couldn't do it, so I took the headlight out to investigate further.
  12. #12 Re: Rear Passenger Strut Tower (WTF)
    It's likely wrong that I'm laughing.
  13. #13 Re: Rear Passenger Strut Tower (WTF)
  14. #14 Re: Rear Passenger Strut Tower (WTF)
    That clamp is amazing but just take 1/2 an hour and swap the strut mount
  15. #15 Re: Rear Passenger Strut Tower (WTF)
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    Hmmm....
    2004 Comp G "The Panda"- low, e85, big brakes SOLD
    2002 Trans Am- 6 speed, bolt ons or something, it's slow.
    2006 Silverado- forged ls2, 4l80e, plate kit, also slow...
  16. #16 Re: Rear Passenger Strut Tower (WTF)
    Banned
    Oct 2013
    Moorhead, MN
    Thanks for all the input guys.
    Is that considered a body mod?
    That clamp is so rusted I can't get it off. I'll probably order the white plastic piece they replaced and just cut it off.
    Will I need a spring compressor to swap the mount? Should I do both?
    Also, do you know of any good strut tower reinforcement brackets?
  17. #17 Re: Rear Passenger Strut Tower (WTF)
    you need a air gun to get the nut off 99% of the time. or take them off the car then drop them off at a front end shop, i had my front mounts changed for 30 bucks, for the pair.
  18. #18 Re: Rear Passenger Strut Tower (WTF)
    A spring compressor is needed. You can pick one up for around $15 at any parts store
  19. #19 Re: Rear Passenger Strut Tower (WTF)
    Or you could borrow a loaner tool from the parts store for free.
  20. #20 Re: Rear Passenger Strut Tower (WTF)
    Yeah but then you have to borrow it again next time
  1. WTB: Rear strut tower brace
    By Pontiac Man in forum Wanted To Buy - Parts
    Last Post: 02-19-2012, 12:44 PM
  2. Strut tower brace front and rear
    By SleeperGS in forum Brakes/Suspension/Chassis
    Last Post: 01-17-2011, 02:16 PM
