Thread: F-Body brake question
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 82
  1. #61 Re: F-Body brake question
    pretty sure all that info is in this thread. http://www.grandprixforums.net/big-b...ead-39174.html
    Buffalo
    Nice. I see know what is needed. Thanks
  3. #63 Re: F-Body brake question
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Quote Originally Posted by crazyguy03 View Post
    Ah I see. So what if I use the c5 caliper ? What bracket would I need ? The fbodys ?
    Again, lol I have all of these but just been running a stock caliper with 12 rotors
    F-body bracket works with C5/C6 calipers
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
    Buffalo
    Thanks for clearing up the confusion
    So I think I'll order those bolts and sleeves
    Props again for the part numbers. I been putting this off as I didn't want drill and tap anything.
    Edit
    Part numbers for the bolts to use with the sleeves ?
  5. #65 Re: F-Body brake question
    Donating User Odi's Avatar
    Chicago South Suburbs
  6. #66 Re: F-Body brake question
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Drill and tap is better and very inexpensive.
    Buffalo
    Anyone have a part number or size bolt if I get them from a hardware store?
  8. #68 Re: F-Body brake question
    come on dude lol it was right there in the link.
    4 12mm fbody caliper bracket bolts (12x1.75x40mm)
    Seattle Club Grand Prix • View topic - FAQ - F-body 12" brake upgrade [ Guest ]
    Buffalo
    Sorry man. I currently been I-phoning for the last month or so, and had 8 windows open all for the bolt website. (been too busy with my house remodeling to get on my pc)I didn't want to order 8 bolts just 4. I rarely beg for help, so props to you for doing the leg work for the info!
  10. #70 Re: F-Body brake question
    not a problem, anything for a fellow regal owner.
    just bustin your nuts a bit anyways.
  11. #71 Re: F-Body brake question
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    do i absolutely have to get SS break lines to do this upgrade or can i just use the stock lines?
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  12. #72 Re: F-Body brake question
    pretty sure you can use the stock line, they may have to be f body lines.
    the ss line makes the pedal firmer i guess, no rubber to swell.
  13. #73 Re: F-Body brake question
    stock lines are too short. need to get longer fronts.
  14. #74 Re: F-Body brake question
    Dec 2010
    Canada
    Quote Originally Posted by asite57 View Post
    Stock works. They're short, so you just bend the holding tab a bit. You need the right Banjo bolts, too.
  15. #75 Re: F-Body brake question
    Houston/Baton Rouge
    Quote Originally Posted by mechguy View Post
    x2
    Just be careful and dont let them hang
  16. #76 Re: F-Body brake question
    Oct 2011
    Michigan
    banjo bolt?? where do this go is this what hold the end of the brake line to the caliper?
  17. #77 Re: F-Body brake question
    the banjo bolt is the bolt that holds the line to the caliper, you need the F body caliper banjo bolt.
  18. #78 Re: F-Body brake question
    Oct 2011
    Michigan
    ok thats what i thought i just wasnt 100% sure, does SS lines relly firm up your peddle or is it just a gimmick
    Buffalo
    What if the calipers from the fbody have the brake lines attached already? I can use those bolts to attach my lines right?
  20. #80 Re: F-Body brake question
    What if the calipers from the fbody have the break lines attached already? I can use those bolts to attach my lines right?
    those should work.
  1. body question guys
    By clevelandfan in forum Visual/Body Modifications
    Last Post: 04-30-2011, 11:12 PM
  2. Body Question
    By Kenny75k in forum Visual/Body Modifications
    Last Post: 11-24-2010, 10:37 PM
  3. body year question
    By PLAYTME in forum General Tech Discussion
    Last Post: 10-30-2010, 10:55 PM
  4. Break Question
    By nikkigpgt00 in forum Brakes/Suspension/Chassis
    Last Post: 03-19-2010, 01:48 AM
  5. disk break question
    By kjohnson in forum Visual/Body Modifications
    Last Post: 06-08-2009, 04:24 PM
