Thread: 2007 gp sway bar options
Results 1 to 12 of 12
  1. #1 2007 gp sway bar options
    Jul 2011
    Edmonton, AB
    I want stronger/stiffer sway bars for my 2007 gp. Is the any options? It seems all upgraded sway bars are for pre 04..
    Wizaired CAI, ZZP Headers & DP, SLP cat-back, 1.8 RRs
  2. #2 Re: 2007 gp sway bar options
    sway bar bolts to LCA correct, for your car?
    Then the sway bar is the same as the 97-03.
  3. #3 Re: 2007 gp sway bar options
    Jul 2011
    Edmonton, AB
    Yes my front sway bar bolts to the LCA.. What about the rear?
  4. #4 Re: 2007 gp sway bar options
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Quote Originally Posted by 2007gpgt View Post
    all the same. 97-08
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  5. #5 Re: 2007 gp sway bar options
    Banned
    Sioux Falls, SD
    The dorman sway bar is solid and alot heavier!
  6. #6 Re: 2007 gp sway bar options
    Jul 2011
    Edmonton, AB
    Im thinking il go with the dorman for the front I believe its 35mm.. Whats the stiffest sway bar available for the rear? I want as stiff as a suspension I can get without lowering my car (roads here are sh1t)
  7. #7 Re: 2007 gp sway bar options
    http://www.grandprixforums.net/swaybar-sizes-40056.html
    Apparently you can do coilovers and leave them at stock ride height, but no one recommends running coilovers in the winter.
    Unless you like to clean them often.
    You could run bilsteins and vogtland or SSC springs.
    That'd put you pretty close to stock ride height if not the same.
  8. #8 Re: 2007 gp sway bar options
    Jul 2011
    Edmonton, AB
    In that thread is says slp rear bar is 25mm but 3800 performance says 3/4" or 19mm.. Can anyone confirm this?
    Coil overs wouldnt be a problem for me I store her for the winter and I could probably get away with a 1" drop without scraping everywhere only thing im worried about is a real harsh ride especially because im on 20s..Anyone run upgraded swaybars on stock springs/struts and will it make a noticable difference in the corners or should I just suck it up and get a mild lowering spring with a stiffer spring rate?
  9. #9 Re: 2007 gp sway bar options
    Jul 2011
    Edmonton, AB
    Slp sway bar set on 3800 performance says 1-3/8" front and 3/4" rear..i beleive thats 34-35mm and 19mm..I thought someone made a 25mm rear bar?
  10. #10 Re: 2007 gp sway bar options
    Ask odi what size his SLP bars are.
    They're quite over sized.
    ADDCO bars are available from summit racing and the like.
    They make some stupidly large rear hollow bar, but its well over $200 just for the one bar.
    I went with front dorman and rear addco solid (7/8ths) as that was the largest for the least money in the realm of solid.
    Local dealerships here still charge $100+ for each GMPP bar.
    GM parts direct doesn't ship to canada. But their canadian division requires a credit card before they'll even give you a price on the product. Seems off really.
    Sways will make a large difference. Mostly the front bar.
    Slps should be 1" ask odi, the op of that thread. He has a set.
  12. #12 Re: 2007 gp sway bar options
    Houston/Baton Rouge
    Stock Front = 28mm - Hollow
    Stock Rear = 17mm - Hollow
    GMPP Front = 34mm Hollow
    GMPP Rear = 19mm Solid
    Progress Front = 34mm Solid
    Dorman Front = 34mm Solid
    SLP Front = 35mm Solid
    SLP Rear = 25mm Solid
    BMR/Addco/Speedbuilt/Next Level Front = 1-1/4" or 32mm - Solid
    BMR/Addco/Speedbuilt/Next Level Rear = 7/8" or 22mm - Solid
    RAT Front = 1-1/4" or 38mm - Solid - No longer made
    RAT Rear = 1-1/16" or 27mm - Solid - No longer made
  1. need options
    By redlinepontiac in forum Off Topic Discussion
    Last Post: 12-31-2011, 11:00 PM
  2. 2007 Grand Prix GXP Snow Tire options
    By GPGXPTyler in forum Tires & Wheels
    Last Post: 12-05-2011, 11:44 PM
  3. H/U options
    By BLWNPontiacs in forum Audio, Security & Visual Electronics
    Last Post: 09-28-2011, 09:40 PM
  4. sway bar options
    By GMPUNK in forum Brakes/Suspension/Chassis
    Last Post: 10-20-2010, 11:36 PM
  5. What are our options?
    By gdbyrd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-14-2009, 12:17 AM
