Thread: Replacing struts??
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
  1. #21 Re: Replacing struts??
    Jan 2012
    Philadelphia
    if you buy the complete strut you dont need to compress it its easy to install
  2. #22 Re: Replacing struts??
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Quote Originally Posted by rbdelpippin View Post
    Wow I read the first couple of posts and was like 'these guys are crazy!' The whole spring compressor thing is unnessary unless you are trying to install a combination of performance parts or something. [/url]
    -rdp
    Umm, its pretty necessary when you want to install new struts and your stock springs are FINE!!!!!!!!!!!!!
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  3. #23 Re: Replacing struts??
    Apr 2012
    houston
    Yeah the ones I got were for my daily driver - same thing as the econo line. They are stiff but the ride is so much better with new struts and I don't have to worry about my car shaking apart now. Yeah definitely always replace in pairs- or even better all four corners if you can afford. The reason my shop let me get my struts off that website is because they basically copy OEM perfectly (according to my guy at the shop). They came with the strut, spring, and top mounts already assembled.
  4. #24 Re: Replacing struts??
    SE Level Member thenose's Avatar
    Apr 2012
    Athol, Massachusetts
    Quote Originally Posted by malmar112 View Post
    If i buy the complete strut do I still need to compress it. Also do I really need to buy new end links for my sway bar? I just replaced the sway bar porbably about a month ago. lastly, thank you for all the responses.
    I just put a complete Quickstrut in the rear of my GTP and it was all complete and easy to do. Took about an hour or so, and most of that was trying to get the holes all lined up again. Took one big part out, put one big part back in.
  5. #25 Re: Replacing struts??
    Sep 2011
    Logansport, IN
    I can tear my struts out and change the springs on both in about an hour......guess I just have too much experience at doing it lol.
  6. #26 Re: Replacing struts??
    i did it taking my time over an afternoon for all four corners and i was done before dinner time without trying.
  7. #27 Re: Replacing struts??
    Omaha, NE
    This is false. Failure to use a proper spring compressor can result in serious injury or death.
  8. #28 Re: Replacing struts??
    michigan
    Yup, i know a guy who was using one and the clamp slipped off releasing the spring resulting in a wired jaw! Be careful ppl!!
  9. #29 Re: Replacing struts??
    Jul 2010
    upstate NY
    Wow, KYBs too stiff? I thought when I put all 4 in that they should have been tighter. But 30K miles later, the KYBs are still working great. No sign of float which got me to change the factory struts at 70K.
    For the fronts, I ordered all the individual parts but an older GM front drive car I had broke a rear spring at 80K. So seeing the rear springs are prone to breaking, I got the complete assemblies for the rears. Yes they are easy to install as an assembly but cost $40 more per strut.
  10. #30 Re: Replacing struts??
    canal winchester, ohio
    Guys, are these struts junk? Monroe Econo-Matic Complete Strut Assembly Part No. 181661
    or should I get
    Monroe Quick-Strut Complete Strut Assembly
    Part No. 171661
    Replacing my struts and I figure I better get the quick struts.
  11. #31 Re: Replacing struts??
    SWPA
    I've been running them for over a year with zero issue.
  12. #32 Re: Replacing struts??
    Banned
    I have a complete set of KYB assemblies that I would sell for a good deal. They have less than 500 miles on them. I wanted something more sporty so I got Bilsteins
  13. #33 Re: Replacing struts??
    How much?
  14. #34 Re: Replacing struts??
    Banned
    Quote Originally Posted by michael redmon View Post
    How much?
    $250 meet near the IN/OH border? They look brand new
  15. #35 Re: Replacing struts??
    Sent you a message
  16. #36 Re: Replacing struts??
    Jan 2012
    Valencia
    Good deal. If deal falls thru. I'm next, but I'd have to meet at the CA/NV border if cool.
    Jk.
    Daniel - Code name ILMODC (il-maude)
    Current ride: 2000 GT, 1998 GTP (wifes) -
    Work in Progress: 1987 Trans Am – KnightHawk Edition (5.3 LSSwap)
  17. #37 Re: Replacing struts??
    Banned
    ILMODC PM'd
  18. #38 Re: Replacing struts??
    I put in the cheapo Unity struts from Completestruts.com tonight. They are solid and heavy, just like the OEM struts. They make the car sit high but it doesnt really bother me. I will post some pics and give a ride report next week after I change the CV Axle. They were easy to install and hopefully they last for a few years. They were awfully cheap (@$230 for all 4).
  19. #39 Re: Replacing struts??
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I bought the Comp G spec (OE spec) monroes for the rear and they ride fine after a year. I had KYB on there and when I took them off to put the new comp g springs and struts back on one front and one rear KYB were blown out. No leak but absolutely no rebound in them. The KYBs were on for about 1 1/2 years.
  20. #40 Re: Replacing struts??
    http://i36.photobucket.com/albums/e4...psflhlemix.jpg
    I dont feel the car looks too high. It rides pretty nice.
  1. 2001 GTP - Replacing Struts - KYB GR2 plus other parts?
    By zguy in forum Brakes/Suspension/Chassis
    Last Post: 03-19-2012, 10:14 PM
  2. Best struts??
    By MEaston91 in forum Brakes/Suspension/Chassis
    Last Post: 02-16-2012, 07:39 PM
  3. struts for 07 gp
    By sca555 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2012, 02:26 AM
  4. 97-98 struts vs 99-03 struts
    By joshua_arndt in forum Brakes/Suspension/Chassis
    Last Post: 01-15-2010, 02:44 PM
  5. GXP struts
    By silvermistgt2002 in forum Brakes/Suspension/Chassis
    Last Post: 01-12-2010, 09:34 AM
