Thread: Aluminum Subframe
Page 1 of 3 123 LastLast
Results 1 to 20 of 43
  1. #1 Aluminum Subframe
    GT Level Member ls1camino's Avatar
    Laurel, MD
    I just recently purchased all new front control arms (to replace the stock bushings) and a solid front sway bar to replace my GMPP front sway. This seemed like a good time to swap out for the lighter subframe. I read about the 2000 subframes cracking, and to only buy an '01 up aluminum. I ended up picking one up from the junkyard for $35 out of an '05 Impala. I grabbed all the bolts and the cups that go on the top and bottom.
    My question is this...am I at risk for breaking the aluminum subframe under heavy acceleration? I'm only a 3.4 swapped GTP, but I plan on going turbo at some point. I've seem some pictures of air-to-air intercoolers with aluminum subframes in the background, and just wondered.
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  2. #2 Re: Aluminum Subframe
    it depends on how hard the boost hits, which mounts you have, the whole setup. I've seen a couple crack and I've seen most stay together.
    Ask yourself though. Is the weight difference worth the potentially weaker subframe?
    What I would automatically suggest if you plan on doing the frame is to get the aluminum oil pan and it's pickup tube. That pan makes changing the mount or pan gaskets super easy. And it's structural so you won't ever dent it.
  3. #3 Re: Aluminum Subframe
    Laurel, MD
    In a full weight car, every little bit helps. I also have a personal vendetta against rust, so eliminating the steel subframe is eliminating one more rusting part from my car.
    I guess I'll have to keep an eye on the subframe and check it every oil change for cracks. or bends. Are there any indications of a crack other than visual? With my access to a lift so readily available, I'm not shy about giving the aluminum subframe a try. I will definitely not get rid of my stocker, just incase I need to put it back in.
  4. #4 Re: Aluminum Subframe
    Not that I'm aware of. I haven't read much on them cracking though.
  5. #5 Re: Aluminum Subframe
    Which cars came with the alum subframe? I know the 04+ gp's did.
  6. #6 Re: Aluminum Subframe
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    Yup 04+
  7. #7 Re: Aluminum Subframe
    But some impala's and montes came with them too right?
  8. #8 Re: Aluminum Subframe
    Impalas have them and Im not sure maybe montes too
  9. #9 Re: Aluminum Subframe
    Which impalas? I'd like to be able to find one super cheap and swap it out.
  10. #10 Re: Aluminum Subframe
    04 plus IIRC
  11. #11 Re: Aluminum Subframe
    ok i'll have to keep my eyes open for a part out thanks tyler
  12. #12 Re: Aluminum Subframe
    Wanna pay shipping for one? Im sure I can get them by the pickup load for 150 bucks each maybe less.
  13. #13 Re: Aluminum Subframe
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    I don't want to have to hassle with shipping something so large. I'm gonna try some pick and pulls around here. Thanks though
  14. #14 Re: Aluminum Subframe
    Laurel, MD
    2000+ Impalas and Monte Carlos had them, but the 2000 models had manufacturing problems, so look for a 2001+ model.
  15. #15 Re: Aluminum Subframe
    Yup...01+ Monte and Gimpy's. While your there, if it's a Monte..nail the sway too, it's the GMPP one
  16. #16 Re: Aluminum Subframe
    My buddy has an 01 impala think he'll notice if I'm in his driveway for a few hours swapping subframes? Lol
  17. #17 Re: Aluminum Subframe
    memphis
    my 06 lacrosse has one
  18. #18 Re: Aluminum Subframe
    Car-part.com lists them in my area.
  19. #19 Re: Aluminum Subframe
    Closest one to me is in wv. That's a little bit of a drive lol
  20. #20 Re: Aluminum Subframe
    40-15'30'' N 085-40'33'' W
    I migh run to the local scrap yards saturday morning and see what i can find!
  1. subframe bushings??
    By nicks98gtp in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2011, 09:54 PM
  2. dropping subframe
    By Jakegday in forum General Tech Discussion
    Last Post: 10-01-2010, 09:59 AM
  3. aluminum subframe
    By sdenton8 in forum Brakes/Suspension/Chassis
    Last Post: 07-24-2010, 10:33 PM
