Thread: weard squeak ing noize when I turn the wheel
Results 1 to 6 of 6
  1. #1 weard squeak ing noize when I turn the wheel
    SE Level Member rc10gt7090's Avatar
    Jun 2011
    minneapolis
    Ok here’s the deal. my 2002gp gt was making a squeaking noise in the front end so thinking it was the brakes I went ahead and changed the rotors and brake pads. The noise did go away for a day but now it’s back! The noise now gets worse when I turn left and right could this be a wheel bearing going bad and letting the brake pads rub or is it the calipers not releasing all the way? When I had the car on the jack I tested the bearings and they had no play in them
  2. #2 Re: weard squeak ing noize when I turn the wheel
    was there any grease left on the caliper slider bolts?
  3. #3 Re: weard squeak ing noize when I turn the wheel
    Jun 2011
    minneapolis
    yes I pulled them out and put some grease on the sliders and I still have the same problem
  4. #4 Re: weard squeak ing noize when I turn the wheel
    Jun 2011
    minneapolis
    the Only time it wont Squeak is when the car goes backwards any one got an IDEA
    so thinking I had a bad caliper a went and replaced it.
    I still have the same sound.
    now its more when the car is going strate like the brake is hanging up.
    I'v blead the brakes. pins are lubed
  5. #5 Re: weard squeak ing noize when I turn the wheel
    Jun 2011
    minneapolis
    I'v jacked up the car and its only the driver side making the noise unless I'm making a sharp turn then they both make the noise.
  6. #6 Re: weard squeak ing noize when I turn the wheel
    Jun 2011
    minneapolis
    ok so to day i broke down and took the car in.
    they found the dust sheilds to be touching the roters.
    well that was $35 well spent
  1. Dont like to turn left but easy to turn right
    By Randall in forum General Tech Discussion
    Last Post: 02-01-2013, 12:11 PM
  2. High beams turn on intermittently when using turn signals
    By Boomersooner in forum General Tech Discussion
    Last Post: 01-13-2012, 08:31 PM
  3. want to know what my squeak is
    By Fedewaj in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2010, 08:59 PM
  4. Got a squeak that won't go away...
    By Sandman in forum Brakes/Suspension/Chassis
    Last Post: 10-02-2009, 06:12 PM
  5. weird sound when i turn the wheel...
    By gtphayes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-29-2008, 01:33 AM
