Thread: Lower control arm ABS wiring Clips
Results 1 to 5 of 5
  1. #1 Lower control arm ABS wiring Clips
    SE Level Member A70Runner's Avatar
    Dec 2011
    NC
    I replaced my lower control arms on my GP today. Of course all the clips holding the ABS wiring harness broke. Are these avalable anywhere? I went to the local autozone and the 12 year old kid wasn't in the mood to look anything up that wasn't on the screen in front of him.
    Or what did you do to fix this problem.
    Thanks!!!
  2. #2 Re: Lower control arm ABS wiring Clips
    Wichita
    Honestly, I'd zip tie the harness to the control arm & be done with it.
  3. #3 Re: Lower control arm ABS wiring Clips
    Donating Users
    South Deerfield, MA
    I had a hard time finding them too. I tracked them down on clipsandfasteners.com.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  4. #4 Re: Lower control arm ABS wiring Clips
    i used zipties.
  5. #5 Re: Lower control arm ABS wiring Clips
    Nov 2011
    NY
    Ty-Wraps / Zip Ties, whatever you'd like to call them work just fine. Just don't animal them and pinch the cable too much.
  1. 2k8 Lower side molding clips - need part number
    By mscheuler in forum General Tech Discussion
    Last Post: 11-09-2011, 07:18 PM
  2. GTP lower door moulding clips
    By Regalgs98 in forum General Tech Discussion
    Last Post: 03-22-2011, 11:09 AM
  3. 97-03 vs 04+ lower control arms
    By Wicked13 in forum Brakes/Suspension/Chassis
    Last Post: 09-01-2010, 10:17 PM
  4. Lower Control Arms
    By SyntheticShield in forum Brakes/Suspension/Chassis
    Last Post: 05-05-2009, 12:55 PM
