Thread: Axle question
Results 1 to 7 of 7
  1. #1 Axle question
    GTP Level Member 2001goldGTP's Avatar
    california
    So i jhave a gtp and i need a driver side axle. I cant remember if they are all the same on the driver side regardless or being a gtp or not. Can someone tell me so i can get another one, car is prety bad to drive at this point. Thanks
    xp'd
  2. #2 Re: Axle question
    They should be the same. Just tell them your car and they will get you the part. Its not the price is gunna change.
  3. #3 Re: Axle question
    california
    Im trying to get one from morad but they are closed but he has them up on his ebay store, jut nothing says gtp next to it for axles. It just says regal/grand prix/monte carlo lol. I just dont want to get the wrong one and have to ship it back.
    xp'd
  4. #4 Re: Axle question
    What?
    Why not go buy a brand new napa axle with a warranty and have it today?????
    I run napa axles with no problems.
  5. #5 Re: Axle question
    california
    any one have any tips or right ups to remove the axle?
    xp'd
  6. #6 Re: Axle question
    Remove stuff.
    Wheel, then axle nut (thread nut on 1 full turn, and smack it with a mallet to break it looose from the hub.) , then cotter pin from ball joint, ball joint nut, get a LONG pry bar and pop the lower ball joint out, swing the whole brake and caliper with the strut to the side and push the cv out the hub and pull from transmission.
    un bolting the sway bar link on that side will give you more play room, so do that too
  7. #7 Re: Axle question
    http://www.grandprixforums.net/how-r...xle-39805.html
    On the driverside, it's the tougher side IMO to remove the axle from based on the lack of being able to get behind the inner cv cup. While it's a pricey item, Gearwrench 82248 prybar is the ultimate axle removing tool. I was impressed, my mechanic buddy didn't want to give it back and a few other friends have used it. it's simply a great tool for doing these axles.
  1. axle nut torque specs question
    By kyle91 in forum Brakes/Suspension/Chassis
    Last Post: 05-11-2013, 02:47 PM
  2. CV Axle question
    By tootintorrey in forum Brakes/Suspension/Chassis
    Last Post: 05-11-2011, 12:05 AM
  3. axle nut
    By Solo GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-17-2011, 11:56 AM
  4. Is my axle going out?
    By guitarguyucf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-26-2010, 07:05 AM
  5. CV Axle
    By stlmo_gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-30-2008, 01:24 PM
