Hard to tell. If I were you I would jack up the car and take off the wheels on both sides and inspect the wiring from the hub for any broken wires. Most likely if a wire were broke that is were I think it would be due to the amount of debris flying around in the wheel wells. It may be possible that you have a rusted or corroded connection someplace too. If you cant find anything then you could probly get it replaced.
