Thread: no fluid to rr caliper help
Results 1 to 8 of 8
  1. #1 no fluid to rr caliper help
    nj
    Need some help. I just bought a 97 gtp. The previous owner replaced the m/c a few months before I bought it. He advised me that the brakes were soft and it needed to be bled. No problem. I bled the ABS modulator valve then went to the rear brakes. I have no pressure in the rear right caliper and the left had a frozen bleeder valve. Its old so I said to hell with it and bought new calipers for the rear. The left bled fine...the right still has no pressure. I checked the front, they have pressure. I pushed fluid through the caliper with the line disconnected, all good. Pushed fluids through the caliper with the line conneceted...no go. Dissconneced the line @ the modulator valve and pushed fluid through..no problem. The issue seemed to be the modulator valve but I was under the impression. That the rear lines were run off a single valve unlike the front. Is this wrong. Is it possible something I missed. Can the modulator valve be rebuilt? What are my options. A new modulator valve is $5000...I rather not spend that if I don't have to. Any help would be great
  2. #2 Re: no fluid to rr caliper help
    nj
    Sorry too many zeros. That's 500 not 5000
  3. #3 Re: no fluid to rr caliper help
    Did you try starting the car and bleeding them? Maybe there is a little blockage and the extra pressure will help you bleed them.
  4. #4 Re: no fluid to rr caliper help
    nj
    Yeh tried that too. I tried everything I could think of. Pressure bleeding vacuumed bleeding... nothing from thar line as long as its connected to the valve body.
  5. #5 Re: no fluid to rr caliper help
    GT Level Member MBruneaux's Avatar
    Canterbury, CT
    Post in the wanted section for an ABS module or call a junkyard for a used one.
    2001 Grand Prix GTP - Daily Driver12" front brake upgrade ('05 Monte), Raptor tune, Open cone, Front and rear strut tower braces, SS brake hoses, BMR trailing arms, ZZP 3" catted downpipe, Dorman front sway bar, GMPP rear sway bar, solid trans and engine mount, flipped dog bones and Borla exhaust.
  6. #6 Re: no fluid to rr caliper help
    $40 at the JY I go to..
  7. #7 Re: no fluid to rr caliper help
    nj
    LOL how much o have u pull it for me? I live in NJ and the junk yards here are retarded. Its damn near retail for anything
  8. #8 Re: no fluid to rr caliper help
    nj
    Dropped it off to my mechanic for an alignment today. He's gonna take a look @ it for a second oppinion. Hopefully I've been over thinking it and its something simple and cheap
  1. Need P/N CompG Caliper
    By SlowNA06 in forum Brakes/Suspension/Chassis
    Last Post: 11-19-2010, 01:15 PM
  2. What Caliper Color?
    By Black18Ice in forum Visual/Body Modifications
    Last Post: 11-07-2010, 10:21 AM
  3. caliper bracket
    Last Post: 08-16-2009, 02:04 PM
  4. Caliper pin orentation?
    By Iron Indian in forum Brakes/Suspension/Chassis
    Last Post: 10-20-2008, 12:29 AM
