Thread: Replacing Front Sway Bar
Results 1 to 12 of 12
  1. #1 Replacing Front Sway Bar
    Dec 2011
    Montreal
    The sway bar on my 98 GT is broken and I got another one from a scrap yard. After removing the bolts and links, can I just slide out from it's location or does the engine have to be raised or the cradle lowered?
    Thanks,
    Ian
  2. #2 Re: Replacing Front Sway Bar
    slide it out, with a twist. you can support the cradle and unbolt the 2 back cradle bolts like 2 inches, and lower the frame a bit, so you can get to the back bolt on the drives side more easily if you like or just do the slow bolt turn like you did to get it off. watch the brake lines there.
  3. #3 Re: Replacing Front Sway Bar
    Nov 2011
    NY
    Or just take one wheel off, disconnect the end link and the tie-rod end (mark where the nut is so you put it back where it was) and slide the bar out on that side, easy... I did it through the passenger side. Go for Energy Suspension Poly Bushings and Poly End Link Bushings... you'll be happy you did!
  4. #4 Re: Replacing Front Sway Bar
    Dec 2011
    Montreal
    Thank you, I'm happy it will slide out without too much trouble. For the time being, I'm using the original bushings and mounting hardware. I might go with lowering springs in the next couple of months, if I do, I'll swap out all the old bushings at the same time.
    Ian
  5. #5 Re: Replacing Front Sway Bar
    1. If you lower the rear of the subframe, it'll take you half the time.
    2. You can do it w/o lowering or taking off the tierod. I've never touched a tie rod to swap a bar.
    3. While you are there, if you are ever going to mod the car, point the center bump downward instead of up. This will put you in a good place if headers ever go on the car.
  6. #6 Re: Replacing Front Sway Bar
    GTP Level Member buickman104's Avatar
    NYC
    All it takes is practice. I have done about 5 sways and it takes me 15 minutes on jackstands on the street. I've never lowered the subframe.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  7. #7 Re: Replacing Front Sway Bar
    Dec 2011
    Montreal
    Thanks all for the info, I'll do it this weekend.
    Ian
  8. #8 Re: Replacing Front Sway Bar
    SE Level Member A70Runner's Avatar
    Dec 2011
    NC
    Ok I change mine today. It was so much easier to drop the rear bolts on the subframe. The only question is does anyone know the torque on the bolts on the subframe?
  9. #9 Re: Replacing Front Sway Bar
    real tight. make em as tight as you can with a breaker bar.
  10. #10 Re: Replacing Front Sway Bar
    Dec 2011
    NC
    Ok next question....Just read on another forum that you should unhook the steering linkage before dropping the cradle. Guess what....I didn't know that and just dropped the cradle to get the bar out. Any ideas how bad I screwed up?
  11. #11 Re: Replacing Front Sway Bar
    you dont need to unhook anything to drop the cradle 2 or 3 inches. your fine.
  12. #12 Re: Replacing Front Sway Bar
    Portland Oregon
    Quote Originally Posted by A70Runner View Post
    130 ft lbs per the FSM
  1. front sway bar
    By Toasty in forum General Tech Discussion
    Last Post: 03-23-2013, 12:34 PM
  2. Front Sway Bar
    By 1SICKGP in forum General Tech Discussion
    Last Post: 09-01-2010, 10:20 PM
  3. Null
    By kswissbob in forum General Tech Discussion
    Last Post: 01-04-2010, 08:54 PM
