Thread: ABS Code C1242
Results 1 to 20 of 27
  1. #1 ABS Code C1242
    GT Level Member ljmonnin12's Avatar
    Nov 2010
    Sidney, OH
    I had my car in the shop to have both front hubs replaced. Which is what i thought was the only thing wrong. Turns out I was wrong. My car is throwing C1242 which is a faulty motor pack assembly. I have no idea what that is, how much it costs or anything. Any advice on maybe how to fix it or something? Anything would help. Thanks.
    -ljmonnin12
  2. #2 Re: ABS Code C1242
    Does that mean the abs module needs replaced?
  3. #3 Re: ABS Code C1242
    Pennsylvania
    Sounds like it needs a rebuild to me. $150. No big in the grand scheme.
  4. #4 Re: ABS Code C1242
    Nov 2010
    Sidney, OH
    Where can I get it rebuilt at? I know there is module master, but they don't fix 97 modules.
    -ljmonnin12
  5. #5 Re: ABS Code C1242
    Pennsylvania
    Oh. Ooh. Uh.
    Take a picture of your module for us. We'll tell you what it is. Module Master has their pictures and car years all borked. We won't lead you astray.
    Also worth checking out: http://www.cheapabs.com/vrsaab.html
  6. #6 Re: ABS Code C1242
    Junkyard.. Say $40 for a used one.
  7. #7 Re: ABS Code C1242
    Pennsylvania
    Which is awesome if you're that strapped for cash, except that stock ones break... in five years, or next week - you never know. Rebuilds should never have an issue again.
  8. #8 Re: ABS Code C1242
    I've seen my share of new parts going back quick as well. There's no way to know when something goes bad, new or used. Just saying..the world isn't perfect. Why pay more than needed for an older car repair.
  9. #9 Re: ABS Code C1242
    Nov 2010
    Sidney, OH
    Ok. I have another question too.... What is variable steering?.... And do I have it?
    -ljmonnin12
  10. #10 Re: ABS Code C1242
    Pennsylvania
    Is magnasteer on your RPO sheet?
  11. #11 Re: ABS Code C1242
    Nov 2010
    Sidney, OH
    I have no idea.
    -ljmonnin12
  12. #12 Re: ABS Code C1242
    Open your trunk and look on the lid. That is your rpo sheet but i forget the code it's supposed to have for magnasteer.
    Nov 2010
    Sidney, OH
    Ok. I'll check it out.
    I am here: http://maps.google.com/maps?ll=40.291370,-84.313929
    -ljmonnin12
  14. #14 Re: ABS Code C1242
    FE3 is one of the codes, nv7 also i think for the rpo's for magnasteer. if you no longer have a sticker, (under you trunk lid) look under your car at the rack and pinion where the steering shaft hooks up,(drivers side) there will be a wire leading up to the back of the engine, if its there you have magnasteer.
    Nov 2010
    Sidney, OH
    So if I have it that means I have variable steering?
    I am here: http://maps.google.com/maps?ll=40.294814,-84.321688
    -ljmonnin12
  16. #16 Re: ABS Code C1242
    yes sir.
    Nov 2010
    Sidney, OH
    NV7 was present. Thanks for the help.
    -ljmonnin12
    -ljmonnin12
  18. #18 Re: ABS Code C1242
    having issues with the rack too?
    Nov 2010
    Sidney, OH
    The rack?
    -ljmonnin12
    -ljmonnin12
  20. #20 Re: ABS Code C1242
    The steering rack. I just assumed that because you were asking about magnasteer.
  1. Need help with a no code
    By 2mad in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2011, 06:59 PM
  2. RPO code tag
    By Wicked13 in forum General Tech Discussion
    Last Post: 05-04-2010, 07:34 PM
  3. maf and tps code
    By transkiller in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2010, 11:51 AM
  4. SES Code
    By josemolina2008 in forum General Tech Discussion
    Last Post: 02-16-2010, 03:11 PM
  5. code...
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2009, 12:22 AM
