Thread: Replacing CV Axle
Results 1 to 3 of 3
Threaded View
  1. #1 Replacing CV Axle
    SE Level Member BlackGT1's Avatar
    Sep 2011
    Fort Worth, Texas
    I found out a short while after I bought my car that the CV Boot was ripped and that it should be replaced. I haven't had time to do so, but now I want to make it more of a priority. I talked to my Uncle who is a Tech and said that if the boot has been ripped that long it is most likely that I need to replace the whole CV Axle. This was about 4 months ago he told me this. I had at the time exerienced a little pop close to turning the steering wheel close to max from the right side, but that has stopped. The only thing that happens now is the Right CV Axle makes a pop noise when going from Park to Reverse, and Reverse to Neutral. It also makes a slight noise when dropping below oor going above about 30mph. I wanted to know you guys opinion on if it needs changed? If so how difficult is it for me to do it? And should I get a Remanned part or a brand new one?
  1. Possible Bad CV Axle?
    By mlasnoski in forum Brakes/Suspension/Chassis
    Last Post: 10-11-2011, 02:47 PM
  2. axle nut
    By Solo GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-17-2011, 11:56 AM
  3. Is my axle going out?
    By guitarguyucf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-26-2010, 07:05 AM
  4. axle
    By tylersgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-01-2010, 07:35 PM
  5. CV Axle
    By stlmo_gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-30-2008, 01:24 PM
