Thread: Shaking/vibration
Results 1 to 11 of 11
  1. #1 Shaking/vibration
    Donating Users zildjian102's Avatar
    Wilkes Barre, PA
    Ok guys I've been trying to track down what is causing my car to shake.. so far I've replaced outer tie rods ball joints and the drivers side cv axle. The shaking seems to get worse when the engine is under load. I noticed yesterday when I had a car full of people that it is ten times worse.. especially when going up a hill. You can feel it in the whole chassis and the steering wheel.. I don't know what else it could be.. possibly a bent rim? Now my abs and trac light are on and the code says the front passenger speed sensor so the wheel hub must be going bad? Anybody ever have any of the problems I'm describing?
    Sent from my SCH-I500 using Tapatalk
    2002 Grand Prix GT- top swap soon
    1997 Pontiac Grand Prix GTP-project/parts
    3.4 pulley, intense tune, SD headers, intake, 180 tstat, al104's
  2. #2 Re: Shaking/vibration
    lowered? either way check your engine and tranny mounts. when they fail the axle geometry is off and causes vibrations.
  3. #3 Re: Shaking/vibration
    Nov 2011
    NY
    Quote Originally Posted by zildjian102 View Post
    The Hub/Bearings can cause that yes... but I'm not saying that's what it is, lol.
  4. #4 Re: Shaking/vibration
    St. Louis
    Yes, I just had this issue and it was the front tires. Once I replaced them all vibrations stopped. Maybe have the balance checked on your front tires.
  5. #5 Re: Shaking/vibration
    Wilkes Barre, PA
    The car is not lowered and i just got new tires.. ill check into the motor mounts
  6. #6 Re: Shaking/vibration
    Feb 2010
    TN
    mounts
  7. #7 Re: Shaking/vibration
    Donating User Odi's Avatar
    Chicago South Suburbs
    axle geometry off. like they said, motor/tranny mounts.
    Wilkes Barre, PA
    Big job to change those?
  9. #9 Re: Shaking/vibration
    Nov 2011
    NY
    You didn't mention this in your original post...
    So, then to dissect the problem, was there any vibration PRIOR to getting the new tires? Weights put onto the wheels for balancing do come off sometimes and also there are times the person balancing them really don't do a good job. If the vibration started AFTER getting the tires I would go back there and have them re-balance them pronto! But with the TCS/ABS light coming on, there's definitely something going on at the wheel/hub, check and make sure the connector/wire for ABS is attached to the hub as well, who knows, maybe it was dislodged when they installed tires?
    Just trying to give $.02
    Wilkes Barre, PA
    Ok lol. The vibration has been there before the new tires.. I do have a p1811 code so with the tranny shifting hard it could be putting more stress on the mounts when shifting..
  11. #11 Re: Shaking/vibration
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Does the vibration seem worse when turning to the right or when accelerating over 60mph? I have had this problem with my car for 3 months now and have replaced the tierod ends the passanger motor mount and still have the problem. I have read up on this problem on many other forums. Everyone says its the cv axels but mine have no play in them. The cv axel is loose in the transmission tho so there may be a bad bearing or thrust washer in the transmission.
  1. vibration,shaking....horriable ride
    By bowsox88 in forum Brakes/Suspension/Chassis
    Last Post: 11-17-2011, 11:43 AM
  2. engine rough shaking/ chugging vibration
    By jordan61488 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-26-2011, 02:58 PM
  3. 02 GTP shaking
    By y2ed in forum General Tech Discussion
    Last Post: 09-27-2010, 03:19 PM
  4. shaking...
    By Couch in forum General Tech Discussion
    Last Post: 07-09-2009, 10:25 PM
  5. Car shaking
    By Davisgtp in forum General Tech Discussion
    Last Post: 05-30-2009, 12:51 AM
