All,
I want to replace my struts on my 2001 Grand Prix GTP. It has about 110k miles on it. I am having some issues with tire wear and will be replacing the tires soon but want to do the struts before that. Once the struts are replaced I will have it aligned. The car does not seem to have an excessive bounce it sure looks like the ride has deteriorated over the years. I am hoping this repair will be noticeable once completed.
I see that struts are available at a variety of locations. E.g. Tirerack, Rockauto, Amazon, etc. I am struggling to determine what parts I need to order so that I can do the job over the weekend and not be forced to order more parts later.
I know I need to order the front and rear struts for the car. I know what those part numbers are so I am not concerned about that. My concern is what else do I need to replace while I have them disassembled? E.g. Boot, mount, bearing plate, etc?
It looks like at the very least I want to replace the rubber mount that is visible under the hood. I believe there is also a little bit of float with original struts on the car. I am not sure if this includes the bearing plate or if it is a separate part.
Any suggestions on what I should replace aside from the strut assembly itself?
Here are some of the parts I see that are offered by KYB from the Tirerack:
GR2 Front assembly# 339015
GR2 Rear assembly# 334228
Front strut mount #SM5568 (How does this differ from SM5143?)
Front strut mount #SM5143 (Same question as previous part?)
Front boot #SB127
Rear boot #SB105
I appreciate the help!
