Thread: Rear Sway Bar install tips, tricks or something?
Results 1 to 10 of 10
  1. #1 Rear Sway Bar install tips, tricks or something?
    GT Level Member fireprix's Avatar
    Virginia
    So I'm upgrading the rear sway in my 04 GP, and i'm having major issues, i got the old one out, though not without much @$$pain with all the twisting and turning etc. But I can't seem to get the new one in. I have dual exhaust (no, not true dual). Any tips on getting this thing back in there without removing exhaust hangers (which I'm not sure how to do). Anything would be appreciated. And reconfirming that the hump in the middle of the bar goes "up" right? Thanks!
    2004 GP GT2 -- Sold
    2009 G8 GT -- Moar Power
  2. #2 Re: Rear Sway Bar install tips, tricks or something?
    I didn't have any problems with mine going in at all but it helps to have someone on the other side to guide it as you slide it through.
  3. #3 Re: Rear Sway Bar install tips, tricks or something?
    Virginia
    I done figured it out. Felt stupid how easy it was after just taking a break.
    2004 GP GT2 -- Sold
  4. #4 Re: Rear Sway Bar install tips, tricks or something?
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    Definitely helps to have a second person
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  5. #5 Re: Rear Sway Bar install tips, tricks or something?
    What fought you about it?
    ( I have no idea what Nick's talking about )
  6. #6 Re: Rear Sway Bar install tips, tricks or something?
  7. #7 Re: Rear Sway Bar install tips, tricks or something?
    Virginia
    I didn't get a second person, no way in hell was the wife coming out to help. it was actually embarassing how quickly I got everything bolted up when I came at it the next morning. So...can add the gmpp rear sway and the w-body store trailing arms. First thing I did was take it up the mountain. Def a nice improvement.
    2004 GP GT2 -- Sold
  8. #8 Re: Rear Sway Bar install tips, tricks or something?
    Dec 2011
    Orlando, FL
    i did HD end links and GMPP rear sway no problem, but could not get the 24mm bolt out of the trailing arms, not even with PB and an impact @ 170psi. my question to you is: after taking the nut off, did you unscrew that bolt or pound it out? i'm thinking of using a torch and a big f'n hammer, but i'm worried i'll wreck the bolts because i'm not sure if they are threaded all the way thru?
  9. #9 Re: Rear Sway Bar install tips, tricks or something?
    Virginia
    Everything came right out for me. Didn't have a problem with them at all.
    2004 GP GT2 -- Sold
  10. #10 Re: Rear Sway Bar install tips, tricks or something?
    If you are having trouble... lower the braket down and hit it with your gun. Then it'll be free from the rust that's holding it.
  1. eibach install tips
    By BoostJunki3 in forum Brakes/Suspension/Chassis
    Last Post: 06-08-2013, 09:50 PM
  2. cam supporting mods/install tips
    By 05SS45 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 10:34 PM
  3. Any tips or tricks for GMPP sway bar install?
    By nickbuol in forum Brakes/Suspension/Chassis
    Last Post: 09-13-2009, 10:08 PM
  4. Front Sway Bar Install Issue
    By rileystanek in forum Brakes/Suspension/Chassis
    Last Post: 07-12-2009, 11:12 PM
  5. Last minute tips/tricks/suggestions?
    By 99prixgt in forum General Tech Discussion
    Last Post: 05-15-2009, 10:15 PM
